That's not a Digger chassis. Although I don't know offhand which model(s) it was used for.prp wrote: -Bolink Digger
- Has thanked: 1130 times
- Been thanked: 3920 times
There were a few using that type chassis but I think the digger and lil red wagon used the rollers for wheelies
- Been thanked: 4 times
BOLINK DRAG BERRETTA TOO.I think thats what i used to have,its been years.Built it new.don
- highwayracer
- Been thanked: 6 times
That arm was used on the Ultima and Jrx2. The difference is the diameter of the hinge pin hole (Losi is larger). The one pictured is the standard Losi length...so it could also be marketed as a wide arm for an Ultima.njdriver04 wrote:Is this a Andys JRX2 front arm, if not can anyone identify it?
In addition, the short version for the Ultima is also marketed as the Oval Arm for the jrx2.
Ok. These parts came off a Bolink Renegade I am trying to restore. I was told The rear blocks were Associated. But; I've seen different versions of the Associated for this era, and they don't match. Front arms are definately Associated after further review. But; here's the question. What did these pieces even look like for the Renegade. That's what I need to know before continuing my search. Also; does anyone know where I can look to find the pieces I need. Or; does anyone have a donor Renegade sticking back they are willing to trade or sell? The first pic is the complete Renegade.
- Has thanked: 36 times
- Been thanked: 1320 times
bolink probably used associated parts to build that car. it wouldn't be the first time a manufacturer repackage someone else's product.
i would just buy a nice rc12i (i think) and use the parts you need from it on your bolink, then sell of the leftovers.
Yeah, that's an idea. But; I want the correct parts, and I know they were not Associated to start with.
Bolink would have bought them from associated and bagged them under their name. Same as custom works and many others have done
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
I managed to pick up Big Jim's RC motor black book a while ago, I asked the seller to include a motor if he had a spare. This is what he sent, and I am not sure what it might be. (I was looking for a freebie
Epic 19 Japan on the shaft side, endbell has Epic and Japan on the pcb. I assume it is a printed circuit board.
Anyway, 19 turn probably? What about the colour of the can? It looks like it is a anodized greenish tinge. A half metallic washed lime green? I dunno...
- Been thanked: 100 times
I think Epic19 refers to the can version not the wind. The can usually is used for several motor versions as making a different can for each one would be too expensive in the end. The timing is locked at this can so I think it´s a Spec motor. The overall view of the motor looks like a design Trinity introduced with the P2K but it is a newer version for sure.
As there is no sticker, I think it´s an OEM version sold to motor builders who could do their own wind or just relabel.
- njdriver04
- njdriver04
Mystery dogbones,
Center of pin to center of the pin 40mm
Diameter of ball 6mm
Length of pins 11-1/2mm
Diameter of shaft 3mm
A Member suggested possibly Thorp Blackfoot dogbones
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
Trinity/EPIC 19 x 1 spec Komodo motor. (OEM tuner version) Great 19t- only bettered by the Checkpoint Money 19 x 1Diamond Dave wrote:I managed to pick up Big Jim's RC motor black book a while ago, I asked the seller to include a motor if he had a spare. This is what he sent, and I am not sure what it might be. (I was looking for a freebie)
Thank you for the help. I just need to find those era specific parts know. Ebay time!gomachv wrote:Bolink would have bought them from associated and bagged them under their name. Same as custom works and many others have done
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
Can anyone identify the brand and model of this motor?
Thanks Limestang
Thanks Limestang
- Attachments
- Picture1s.jpg (32.61 KiB) Viewed 981 times
- 59 Replies
- 16080 Views
Last post by Diamond Dave
- 106 Replies
- 27106 Views
Last post by mikesofunny
- 431 Replies
- 54615 Views
Last post by Eccentric
- 67 Replies
- 16825 Views
Last post by bearrickster
- 321 Replies
- 42013 Views
Last post by tazz888
- 448 Replies
- 50258 Views
Last post by MelvinsArmy
- 351 Replies
- 47593 Views
Last post by Frankentruck
- 4199 Views
Last post by mrlexan
