V12
Been thanked: 100 times
Post by V12 »
Wow, this was fast.
Thanks! :)
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
hugger19 wrote:what car or truck are these for.
My cheat sheet says, Nitro Hawk, Nitro Street, TRX-3, TCP, SRT and LSII. Also still available from Traxxas.
Been thanked: 498 times
Hugger19, they will also fit an rc10 with some slight mods:
http://www.rc10talk.com/viewtopic.php?f=38&t=16582&hilit=traxxas+bellcrank
hugger19
Has thanked: 24 times
Been thanked: 140 times
Post by hugger19 »
sweet sounds good thanks.
njdriver04
Post by njdriver04 »
Have been looking at this wing for a long time. What is it from?
WhoKnowsWho
Post by WhoKnowsWho »
Not vintage but does anybody recognize the maker of this shock?
Came on a used Slash.
Phin
Has thanked: 82 times
Been thanked: 232 times
Post by Phin »
I think the shock is OFNA.
THE H.P FREAK
Post by THE H.P FREAK »
HI!... Can anyone identify some of these wheels? Mostly the billet aluminum ones. I know the one set is for a Hotshot/Hotshot II/Supershot. Anyone know who made them? The 3 holes ones I have no clue.
THE H.P FREAK
HI!... Also I beleive this RC-10 Sprinter is got a lot of homemade parts on it. But can anyone identify any parts on it? It's got RPM front arms on it. The rear arms are weird looking the center supports actually droop down. The chassis plate doesn't look custom, perhaps some manufacturer made it? Wheels and tires I have no clue. Body? Front bulkhead?
Neal.
Phin
Post by Phin »
Chassis and cage are typical Ascot/RCRC.. The side bars are stretched though.
Body is a McAllister Gambler.
Front bulkhead is RPM....dust it off and you'll see the branding. ;)
Front arms are RPM Truck conversion arms.
Red Wheels are from a Kyosho Sideways and the tires are MRC.
Aluminum wheels with more than 3 holes are Duratrax. Don't remember who made the 3 hole version but they're from a Japanese company. Silver painted dish are Prolines, green are Imex, silver below them are AJ's.
Edit: Forgot the motor...Trinity Speed Gems.
THE H.P FREAK
HI!... Thanks PHIN , for the info. I picked this up for $40. You would happen to have or know where I can see the roll bars unstretched? If I restore this I want it back the way it should be.
Neal.
Phin
Post by Phin »
Lowgear
Has thanked: 120 times
Been thanked: 751 times
Post by Lowgear »
Phin wrote: Don't remember who made the 3 hole version but they're from a Japanese company.
They almost look custom to me but if not, maybe Phoenix brand as they used a similar style.
Phin
Post by Phin »
Yup...they are Phoenix. Just found an old listing for them on eBay.
THE H.P FREAK
HI!... O.k thanks for the info.
So this is what I have come up with so far. Does this look about right?
- Ascot roll cage, chassis and headers.
- McCallister "Gambler" Sprint body/wing.
- 6 gear trans.
- Black RC-10 nose plate.
- Front bulkhead is RPM.
- Front arms are RPM Truck conversion arms.
- rc-10 Worlds rear arms.
- Red Wheels are from a Kyosho Sideways.
- Tires are MRC.
- Motor is a Trinity Speed Gems(12T).
- Tekin TRC 411P ESC.
- Futaba S3003 servo.
- RPM rear axle hubs.
- RC-10 hard anodized front shocks on all 4 wheels.
I've already contacted McCallister and they still make the "Gambler' body and wing. So I'll be ordering that soon. Think I'm going to run the Phoenix billet aluminum wheels I just got. Thinking all white body with bright orange accents to go with my vintage Parma "Hardee's" decal set. Might go a bright orange powder coat on the roll bar and front nose plate. I have some white RPM front/rear control arms I'll probably use. Debating if I'm going to run a 6 gear or a Stealth trans. I need to finish off a few more projects before digging into this one. Probably start collecting parts soon.
These are the Vintage Hardee's decals I'm thinking of using :
Also was it common practice to run one wider rear wheel than the other? I have 4 complete Phoenix billet aluminum wheels with tires. The front wheels and foams are identical. The rear wheels and foams are the same except one wheel and foam is 15mm narrower. Now I know the sprint cars go around a circle in one direction. Is maybe the wider wheel/tire go on the outside and the narrower one on the inside? Just seem weird that the guy bought a set with one narrower than the other.
You can see the set of wheels I'm talking about in the top right hand corner.
Return to “Identifications”
