TRF415 information needed for Yokomo belt drive conversion
- kustomizerz
Re: TRF415 information needed for Yokomo belt drive conversion
Details.
- Attachments
- frontside of upper deck is wider than stock to don't twist the bulkhead.
- P1050572.jpg (64.26 KiB) Viewed 2807 times
- Belt tensioner.
- P1050569.jpg (40.86 KiB) Viewed 2808 times
- Belt tensioner.
- Can you see graphite plate on the bulkhead's wall?
- P1050568.jpg (29.13 KiB) Viewed 2807 times
- The bearing above rear pulley is the thing for anti-slip.
- P1050564.jpg (38.82 KiB) Viewed 2809 times
- mrlexan
- Been thanked: 12 times
Freakin' genius! Not much more needs to be said. Nice work!
www.gojammedia.com
www.gojammedia.com
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Wow,
from the looks of these parts, I can tell you don't only make smart designs but also have some very good tools and skills.
Can I ask what you do in daily live?
There's a tread to put some details on yourself, and at the same time get to know some of the peoples faces here:
http://www.rc10talk.com/viewtopic.php?f=1&t=607
- Dr. Robotnik
Wow that is amazing,
now I no longer need to guess what parts to use on my projects, thanks so much Tak!!!!
Cheers
Ed
Cheers
Ed
- kustomizerz
I'm writer and also designer. Graphic, clothing and shoes are my fields as the job. I don't have any expensive tool. I would make my cars with drilling machine, dremel and standard hand tools like handsaw.
- mrlexan
Someone has a very steady hand. Nice.kustomizerz wrote:I'm writer and also designer. Graphic, clothing and shoes are my fields as the job. I don't have any expensive tool. I would make my cars with drilling machine, dremel and standard hand tools like handsaw.
www.gojammedia.com
www.gojammedia.com
- Mr. ED
I'm using the same tools, but you should never look too close on any of my parts: no patience and a shaky handmrlexan wrote:
I have lots of 0 shaped holes rather than round: the drill allways seems to drift and then i have to make 'corrections'
- Dr. Robotnik
Finally thanks to Tak's efforts I have a belt and pulley set-up for my Yokomo!!!! I will do a mock-up in the next few days if I have time.kustomizerz wrote:Here you are.
Thanks a lot mate!!! I can't wait to make my chassis for this!
- Mr. ED
I've been waiting for you to get on with this project, make sure we get lots o' pics!Dr. Robotnik wrote:Finally thanks to Tak's efforts I have a belt and pulley set-up for my Yokomo!!!! I will do a mock-up in the next few days if I have time.kustomizerz wrote:Here you are.
- Dr. Robotnik
Hahaha not for the want of trying. I have loads of belts which I don't need nowMr. ED wrote:I've been waiting for you to get on with this project, make sure we get lots o' pics!Dr. Robotnik wrote:Finally thanks to Tak's efforts I have a belt and pulley set-up for my Yokomo!!!! I will do a mock-up in the next few days if I have time.kustomizerz wrote:Here you are.
But I have the solution thanks to Tak and am ready to build my runner. I have some nice 2.2 wheels and tires and the correct belts and pulleys (4 of each), and just need to start chopping up a chassis....I will be using a trashed Wonder Dog Fighter as a drill and cutting guide, then adding the battery slots from an optional RPS graphite chassis.
I am also hopefully going to be able to mod. some Team Suzuki wheel hubs which should look trick!
So much to do lately! Yikes.
- Dr. Robotnik
Thanks mate, I appreciate it.YZ-10 wrote:nice project
I hope to get a rough mock up this weekend...fingers crossed.
I know this is an old thread, but I'm eager to see if you have any updates for us. I'd love to do this with my SE.
BTW-It may be just the cobwebs in my mellon talking, but I seem to remember there being a belt conversion on the market for these Yokes back in the day. I remember it being EXPENSIVE (believe it came with a new chassis, center brace, etc) and tempermental. Like I said. May just be my faulty memeory mixing things up. There were of course later belt drive Yokes, Optimas, and there was a belt drive conversion for the chain driven Optimas.
Soooo..............any progress???
Eccentric
When did my hobbies become "Old" and "Vintage"???
-RPS Yokomo SE. Novak T4. Revolution stock. Hot Trick dual front shock setup.
-Kyosho Circuit-10 Wildcat Buggy
-Kyosho Nimitz-06. Now that's obscure!
-Marui Big Bear
-Marui Big Bear
- Dr. Robotnik
Hi, yes, there is some broad process. Thanks a lot for your interest. The chassis has been part built for a while but I haven't had time to take pictures. I will do when it's finished. Cheers.
- 2056 Views
Last post by polarbear
- 1544 Views
Last post by magic
- 33 Replies
- 4040 Views
Last post by terry.sc
- 755 Views
Last post by dinglem
- 31 Replies
- 5884 Views
Last post by cas22
- 21 Replies
- 3642 Views
Last post by a01butal
- 2011 Views
Last post by Jay Dub
- 43 Replies
- 9263 Views
Last post by dldiaz
Users browsing this forum: Ahrefs [Bot] and 8 guests
