- m_vice
- Has thanked: 36 times
- Been thanked: 1320 times
- m_vice
Thanks scr8p you tha man! , What about the car they go in? anyone?scr8p wrote:those springs.![]()
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
Oddly he is right- I have a set mounted on Option House red bodies with the same spring/collar & retainer kit, I don't know if it was just a stiff spring or what ( seems to be ) but they will fit an rc10 shock as well ( perfect for that A&L car )
- m_vice
Thanks, I have a set from Jake that erik go on the A & L car already.
I If had a seconds set of these I would use them.
- airdreams1
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
if guessing is allowed my first bet goes to Parma, second to You-G, third on JG and laston CRP
- airdreams1
I was figuring frog since 1 set of holes on all 3 sets lines up to the alum bulkhead. & The 1 on the right matches the parma shock conversion kit mount exactly. But these are fiberglass, so I dont think parma...
bolink had shock sets that they sold for the frog. i've seen them at my lhs. i'm almost positive it came with those fiberglass pieces, which is why i said bolink.
- Been thanked: 12 times
might be crp
There was a fiberglass CRP shock tower kit for the frog prior to their plastic molded front shock tower set.
Somebody on here was after a set, but I can't find the post.
- transamman908
- Been thanked: 5 times
Look like Bolink. I thought they were from a lowering kit for a hopper or hornet but I check my kit and they are not. The CRP mounts for a frog were different. I was looking for a set a while back and think I asked you Anthony. Not mine, but here are the frog front mounts
It was you!
Went back through my PM's and couldn't find it.
edit found it, August of '09, didn't go back far enough
- airdreams1
- 59 Replies
- 16110 Views
Last post by Diamond Dave
- 106 Replies
- 27155 Views
Last post by mikesofunny
- 431 Replies
- 54758 Views
Last post by Eccentric
- 67 Replies
- 16855 Views
Last post by bearrickster
- 321 Replies
- 42093 Views
Last post by tazz888
- 448 Replies
- 50360 Views
Last post by MelvinsArmy
- 351 Replies
- 47655 Views
Last post by Frankentruck
- 4204 Views
Last post by mrlexan
