25 YEARS OF THE RC10 (See page 1)
slotcarrod
Been thanked: 45 times
Re: THE FIRST 25 YEARS OF THE RC10 (See page 1)
Post by slotcarrod »
Thank you very much, I would love to use them but they are a little small can you send me a larger image? I would like to try to keep the same size images going! :wink:
REMJ666
Post by REMJ666 »
I am using windows photo gallery and the largest size it is allowing me is 500 x 375 :? Sorry...I have changed the maximum dimension to 900 and it is still only allowing them to be that size...Foiled again...
tommy2c
Post by tommy2c »
Would it be possible to add which wing came with each version?
slotcarrod
tommy2c wrote:Would it be possible to add which wing came with each version?
I thought they were the same until the CE and Team car? I may be wrong on this, if you have any info I would love to know?
tommy2c
Post by tommy2c »
OK, mainly I wasn't sure if the graphite came with the 6184 too. I was assuming so from the description of the CE showing the new wing but then I was thinking maybe it meant new as in a change from the graphite-CE and not necessarily new as in first time changed since the beginning. Thanks for the confirmation.
tommykart
Post by tommykart »
while reading through the thread i realized i had a near mint late CE without stealth holes, 4 hole ft shock tower, 6 gear trans, no body, A stamp chassis
my daughter and i are going to get this running, i am making her take it all apart and add a bearing kit
Tom
johnshobbies
Post by johnshobbies »
I recognize that car! #35/35. I got #5.
According to the seller, these cars were from a school in Quincy Il.
slotcarrod
I think you guys have early CE's with dyed parts! :wink:
johnshobbies
Yeah mine most definitely has dyed parts: battery holders, rear body mount, transmission case, wheels (i think), some of the ball cups too :]
Has thanked: 356 times
Been thanked: 470 times
Your correct Rod
Been thanked: 3919 times
I remember seeing the eBay auction with the 6 or so cars that all had holes top and bottom on the 6 gear transmissions. Are these those cars? Looks like it in the pics
johnshobbies
yup it's got the extra holes. the bottom one tapped into something metal.. not sure... haven't cracked it open yet.
tommykart
Post by tommykart »
yep i got it on epay there were 38 i think. I got a futaba magnum jr radio and high speed servos that works awesome the only thing that was dyed on mine were some of the ball cups. the other bad, was diff shaft is stripped ( going to make it 4-40 thread ) still has bushings, mismatched springs, maybe they ran oval, right front bushing was toast. tires looked new only good for the shelf queen, hardened rears had flat spot and cracked from sitting.
also had a sticker that said property of Community H.S. Dist. #99 south
assigned to 10th period table 2 seat 3
68 signal and the names of the 2 people that used the buggy
as far as the screw in the top i did that way back in the day to spray some lube into the trans and the screw on the bottom of the pan i don't know, it doesn't go into the trans at all.
i got mine for about $60 but the last one went for about $90.
i got vintage novak esc , changed tires on rims(PITA!!!!!), bearings, batteries and body on the way.
battle of the 6 gears in the back yard
Tom
tommykart
Post by tommykart »
well i have been getting mine RTR and put bearings throughout,... i think you are right everything is dyed black, but it looks good :lol: . when i was widening the hole for the outdrives ..... white at the core :? ahh well. the screw in the bottom was there to cover the hole they drilled in the transmission like the one at the top. i think this might have been done for lubrication since there were still bushings in the trans
Tom
ASC6000
Post by ASC6000 »
Hey all, I dug around but couldn't find a better place so I'll just ask.
Are there records of the production numbers of the various early kits ?
I ask because I still have the box from my first RC10, hence the screen name.
Edinger with the stamped end.
Any idea how many 6000 Edingers were produced ?
I would think the 6000 was more rare than the 6010 or 6016
No, I don't have the car. A few bits and pieces... and lots of memories.
thanks
