- knixdad
- Been thanked: 4 times
The pulleys look like XX4/Street/Rally Weapon pulleys but those outdrives are clearly not a Losi design.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
number 2 is a rear diff, and number 1 is a front diff. Pretty sure YR4 for the front, and the rear can probably fit a few models, as you have tested in the rear bulkhead. I recall the yr4 had some tweaks to the front bulkhead depending on the model.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
I believe these are SRS delrin shock bodies but I'd like to get more info on them. Specifically: What year were these around; did they use AE shock parts to build; and how well/poorly did they function?
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
My wife has the camera today, so maybe I can get the answer to this question without taking a picture (and hopefully without making myself sound stupid ... LOL!).
I have an almost complete set of older, aftermarket RC10 turnbuckles. The problem is I can't remember who made them. They appear to be made of titanium and are adjusted using large 4-40 nuts that are offset on one end of each turnbuckle. Who can name the manufacturer and/or post a picture of what I'm trying to describe?
Thanks.
Thanks.
Something clever goes here...
- ChisaiKuso
Yep. Thank you. I was searching on Google but couldn't come up with any images to verify my suspicions of what they might be.prp wrote:RCPS Turnbuckle
Now I need to start a "wanted" thread in hopes that someone here will have the one turnbuckle that I'm missing.
- Has thanked: 1129 times
- Been thanked: 3919 times
How do you tell between the rcps and the early Lundsford? I have a couple Lundsford.....somewhere
- ChisaiKuso
I was wondering the same thing since I'm not sure what I actually have. I read elsewhere that the RCPS and early Lunsford look the same.gomachv wrote:How do you tell between the rcps and the early Lundsford? I have a couple Lundsford.....somewhere
- SofaKing
- Has thanked: 40 times
- Been thanked: 5 times
Yup, virtually impossible to tell them apart.ChisaiKuso wrote:I read elsewhere that the RCPS and early Lunsford look the same.
I wouldn't doubt they were the same unit as Kelly's just rebranded.
- minimini
- Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
- Been thanked: 11 times
Jirka wrote:I have 2 Yokomo diffs both with equal size 3mm belt pulleys and thay are both equally wild. But to from Yokomo are those pulleys and outdrives?
Diff 1:
pulley on "diff 1" does have collar only on one side. Maybe some rear diff pulley?
outdrives on diff 1 have many large radiuses
outdrives are maybe from some front diff, since when installed on rear bulkhead, the pulley is in same line with motor mount so it will not fit there
Diff 2:
outdrives do not have practically any radius
will fit nicely to ZY10 94 rear bulkhead
Any info about these diff parts will be helpful.
Jirka
this is a set of ball diff for YR4 II
- Been thanked: 100 times
RCPS turnbuckles were made by Lunsford so exactly the same. RCPS was Cliff Lett´s company.gomachv wrote:How do you tell between the rcps and the early Lundsford? I have a couple Lundsford.....somewhere
- j-sou
Is this a YZ-10, or some other type of Yokomo? I don't know my Yok stuff... and sorry for the crappy pics, it's all I've got right now.
- 59 Replies
- 16055 Views
Last post by Diamond Dave
- 106 Replies
- 27070 Views
Last post by mikesofunny
- 431 Replies
- 54321 Views
Last post by Eccentric
- 67 Replies
- 16808 Views
Last post by bearrickster
- 321 Replies
- 41805 Views
Last post by tazz888
- 448 Replies
- 49869 Views
Last post by MelvinsArmy
- 351 Replies
- 47408 Views
Last post by Frankentruck
- 4196 Views
Last post by mrlexan
