clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
integra22t wrote:so i lost a nut and need some help :( .. its for a set of truck rims to rc10 axels anyone know where i can find 1or 2
im tired of loseing parts .. thredlock comming up
You know... I don't think that was originally a wheel nut, looks like a blackfoot transmission bulkhead nutsert! At least I think that's where it came from, I know it fit into some plastic part so you could screw plates to it.
Chris
Edit: yup there they are at the bottom of the picture in this auction
http://www.ebay.com/itm/Tamiya-Blackfoot-Monster-Beetle-Mudblaster-Brand-New-Transmission-Assembly-1-/380704724532?pt=Radio_Control_Parts_Accessories&hash=item58a3c51634
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
Well spotted Chris 8)
Gone fishing
clm
Post by clm »
Well I have had one of those nutserts in my toolbox since the dawn of time it seems. I don't see them making a very good wheel nut however as the hex is far too small to stop the bearing (or bushing) from working into it and unscrewing it from what I would imagine the left hand one that fell off. Also being as they started with metric threads in them I don't think the rethreading to fit them onto the 4-40 rc10 axles would leave much strength in the long run. You are likely better off finding some aftermarket front axles for the hubs. I remember back in the day I chucked a set of blackfoot axles into the drill press and using sand paper resized them so they fit in the trx1 front spindles, perhaps something similar would work here in a pinch?
Chris
integra22t
Post by integra22t »
thanks guys .. ill problely be changing the front spindles back to jrxt and picking up a set of oem rims later and puting the alum rims up for sale as i want it to be a runner later ... ive got one if anyone needs it
clm
Post by clm »
I have had this front bumper in my junk box for years and have no idea what it is to, it appears to be an aftermarket bumper cut out of black kydex and does not appear to have seen much if any use.
Chris
DennisM
Post by DennisM »
It could be a JG bumper, or a copy of, for the Optima. The corners seems a bit more dull on the JG.
A bit strange that it´s counter sunk on the wrong side.
If it was ever mounted on an Optima and raced, it would show clear signs of it, leaving the impression of the front guard and stretched rear mounting holes.
Gone fishing
clm
Post by clm »
I do believe that is the bottom of it in the picture as I can't imagine a car having negative front kickup, here is a side view also bottom (countersunk side) up. It's a bit blurry but *shrug*
Chris
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
its an oval front bumper, designed to be flat once mounted to the chassis
clm
Post by clm »
Makes sense with the body post holes at the end, and it has a front design similar to other jg bumpers I have seen... the mounting point under the front end however is not one I can find.
Chris
DennisM
Post by DennisM »
That makes more sense - so the holes on the front corners would be for body posts.
Gone fishing
Been thanked: 3919 times
The only car I can think of with a shape like that (kickup midway thru bulkhead) is the optima series, but with the sprocket hanging down I don't think a flat design would have fit it.
Definitely a oval bumper and because of the cutouts I'm thinking JG is right. Parma had similar but were typically not lightened
knixdad
Post by knixdad »
Looks a lot like a Rally style bumper, they always have the low chassis mount point and then kickup to a higher bumper end, to give clearance when jumping.
Just like the Rally Weapon and TC3 Rally conversion bumpers.
I'm with the rest who think it's for the Optima, maybe it was heat-gunned and modded to have that bend? Did JG make that bumper specifically for on-road, or did someone customize the usual offroad Optima bumper?
EDIT: Upon further examination, it looks like if that bumper was used on an Optima, it was moved forward and mounted using only 2 holes instead of all 4, as there's no way it would mount properly with that bend in it. My guess is it's a modded JG Optima bumper.
Are these A&L?
Been thanked: 1319 times
yupper
Return to “Identifications”
