Been thanked: 3919 times
O interesting. Being metric it makes it harder on me- I don't know my metric cars well. I wonder if its a chassis brace for a 1/8 car? That would explain the threaded ends but not the threaded center. Hmm
The wheels don't look familiar at all! Very cool....but not familiar
V12
Been thanked: 100 times
Post by V12 »
[quote="civilguy"][quote="j-sou"]Who used plastic ends on their dog bones? Might be tough to figure out what exactly they fit.
The ones I have are SRM Racing (address is 140 West Street, Fareham, Hamsphire, PO16 0EL, England PH (0329)234262... if anyone on that side of the pond wants to do some digging), and are called POLYBONES. PN is S220 labeled for Hotshot R, Bigwig/Boom F&R. I do not know if they made them or just repackaged them. I also have some NIB steel pivot balls for the Hotshot that SRM had too... much better than the Tamiya aluminum. /quote]
Seeing these dogbones I immediately remembered the name SRM Racing, also the product name Polybones.
But SRM Racing was a shop and distributor, no manufacturer. I think Bill Jones was the owner or had to do with the shop.
We did run these Polybones at our RC10 cars and they were really good, from what I remember they were slightly longer than the original RC10 dogbones also had less weight.
I bought a set of these front wheels from some Hong Kong seller about a year ago, but I have no idea what the make is. I'm looking for a set of rears to match, either 12mm hex or AE-style pin-slotted. Anybody know who makes this wheel and what kind it is? They're pretty close to 2.2".
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Thanks, you're exactly right. :)
EDIT: Just bought a set of fronts & rears from fireboy, $26 plus shipping...not too often his prices are that reasonable! The rears will need some kind of 12mm-hex-to-funky-Tamiya adapter, though...
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
The normal crosspin adaptor from Tamiya (Wild One, Fox) is quite long. I´m not sure Your axles will be long enough - If it´s meant for Your 2wd Mid.
Gone fishing
DennisM wrote:The normal crosspin adaptor from Tamiya (Wild One, Fox) is quite long. I´m not sure Your axles will be long enough - If it´s meant for Your 2wd Mid.
I guess I'll know what I'm dealing with when I have the wheels on the workbench. Where there's a will, there's a way, and I can be a very willful boy--as Mr. Grady told Mr. Torrance in "The Shining". :twisted:
markbt73
Post by markbt73 »
The Wild One/Fox rear adapters are thick (1/2" or so) because those cars have very long rear axles, but the Falcon and Striker rear axles are much shorter, so the adapters are pretty close to the same thickness as a normal 12mm hex adapter. As long as you have axles with cross-pins instead of the normal Kyosho tapers, they should bolt right on. Looking at the manuals, I think the adapters are on the Falcon "C" parts tree, or the Striker "R" parts.
SnoopMaxx
Post by SnoopMaxx »
That's the ones I used on my CE
Falcon C parts 0005236 (C6)
Striker R parts 0115056 (R3)
http://www.competitionx.com/pdf/vehicle-manuals/tamiya-falcon-manual.pdf
http://www.competitionx.com/pdf/vehicle-manuals/tamiya-striker-manual.pdf
http://www.ebay.co.uk/itm/Tamiya-58071-Striker-Sonic-Fighter-R-part-0115056-/120676678225
Morten Max
Thanks guys. markbt73, I'm using modern CVDs with 5mm axles & crosspins so I was thinking I could make those adapters work, one way or another.
hugger19
Has thanked: 25 times
Been thanked: 143 times
Post by hugger19 »
does anyone know this body? or who signed it?
RC10resto
Has thanked: 1488 times
Been thanked: 550 times
Post by RC10resto »
Could use a couple more shots / angles
hugger19
Post by hugger19 »
only pic sorry
Barnfind
Post by Barnfind »
anybody know what this is and if it goes with this car and what it is used for???
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Front suspension "arms" for a parma panther.
Return to “Identifications”
