NIX91 Questions and Answers
Moderator: Seabass
- Minisforever
Re: NIX91 Questions and Answers
Rears are a yokomo CZ-825 deep dish offset 12. That's for the roar 2.1 that associated ram in 91. The 2.2 version of the wheel is part # ZC-835.
- Niki
- Has thanked: 3 times
- Been thanked: 45 times
Sounds interesting as I can't see the problem in my runner.slotcarrod wrote:So I mock fitted up my car and wow the bump steer is huge. Any suggestions?
After tuning the 3d-model with my current real car setup - teoretical measurement for bump in was 1.2 deg when chassis touches the ground (25deg arm travel). With the real car I had hard time seeing anything.
Bellcrank link = 38.5mm
Steering link = 72.8mm
Camber link = 64.1mm
Bump steer spacers = 3x0.8mm
When adding lenght to bellcrank link and bump steer spacers, zero deg bump in can be reached easily.
- slotcarrod
Thanks for the wheel info mini!
Niki, what is the recommended total length of the center bellcrank turnbuckle with ballcups installed?
Rod Littau
- Has thanked: 1129 times
- Been thanked: 3919 times
He listed 38.5mm above, I just checked mine and its shorter. I used the stock bellcrank hole position to guess at length, just like a standard RC10. That gave me some bump steer too so I will try his measurements above soon and see how it goes
- slotcarrod
But is that from center to center of the ball cups or end to end?
Rod Littau
- Has thanked: 25 times
- Been thanked: 143 times
did anyone else have to drill out all the arms and other parts so the pins would fit? also my front bulkhead wasnt drilled out so it could mount to the chassis (the 3 screw holes) i know they are little things but this wasnt a cheap kit not super happy.
Yes all holes have to be made round. This is a limitation of 3d printing when the printer is not your own. He can't control the direction they print the parts and when the holes are vertical vs horizontal they will be shaped differently. I assure you the holes he spec'd are round lol. As Jake mentioned use a 1/8" NEW drill bit (or if you have a .127 ream that is what I use)
I think you will find that the holes are plugged with powder, that's how my parts have arrived. I think it happens during the polish. I believe it is a #43 drill that I used (came with the tap)
- Seabass
- Business Member
- Been thanked: 12 times
Stock dog bones do fit and should not be anywhere close to being too short. Post up some pics of your problem and lets see if we can get your problems sorted out. You are the first person I have heard of having issues with dog bones being too short.hugger19 wrote:well i was told that the stock rc10 dogbones would work but they are a little too short? any suggestions?
+1, I'm using them and they are perfect. What have you done outside the standard recipe? Are you using a spacer in the outdrive and a spring in the stub axle like you should be? Are you using the correct side inner mounts, with the pins inboard of the screws?
hugger19 wrote:here is the pic. used all stock rc10 parts hubs axle dogbone. am i missing something?
your a arm holders are the wrong way round, the pin goes in the inside
ed
- Attachments
- _MG_7721.jpg (77.79 KiB) Viewed 1092 times
Hi, my name is Ed, and im a addict.
- 950 Views
Last post by Y'ernat Al
- 1044 Views
Last post by Doc J33P
- 1511 Views
Last post by olderacer
- 1634 Views
Last post by Mark Westerfield
- 857 Views
Last post by RogueIV
- 45 Replies
- 17775 Views
Last post by Niki
- 4974 Views
- 59 Replies
- 10926 Views
