PB buggies. Post your pics.
- Regular Member
- Incredible_Serious
- Has thanked: 1735 times
- Been thanked: 1145 times
Re: PB Mini Mustang. Post your pics.
If you can't wait until the weekend..... I already have the Mini Mustang manual and 2-speed instruction sheet in .pdf.... just PM me an e-mail address, and I'll send what you need through...
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Maxima
It's been a while since I've added any pics to this thread but my Maxima (and Mustang) have undergone lots of TLC over the past 18 months.
I decided to customize a saddle chassis among other things and I am really happy with how it came out.
Here's my Maxima,
Here's my Maxima,
- Bormac
Mustang mod-
Back when Alex ran his Mustang at Knox/Victoria on the day leading up to the enduro we found the rear most part of the chassis spine broke off when it came into contact with the track surface one too many times. Sadly this pretty much rendered the chassis spine useless and a valuable lesson was learnt.
To combat this I came up with the idea to fabricate a plate of 1.6mm firbreglass to cover and protect this area.
I thought this might be a good idea to share with anyone else wanting to run their Mustang.
- Bormac
PB diff issue
Another real issue I have had with both my Mustang and Maxima has been with the metal diff parts.
Running in high grip situations coupled with stonger voltage (lipo's), esc's and motors I have found the steel diff outdrive parts to cause issue. Where the little M2.6 cap head screw goes through one outdrive and into the other there seems to be a weak point where part of the male side of the outdrive snaps off when put under high stress (landing from jumps anyone
). This has caused me issues with both my runners and I came up with a stronger solution.
My friend Thomas (aka-Bugle) helped me out by drilling out and maching a M3 thread right through the male side of the outdrive. Both items need to be machined to make this work. This removes the fragile stepped down section and allows the M3 screw to pass from one outdrive through to the other.
Now I run M3 high tensile screws through all my diffs and the weak portions of the diff are no longer there. Originaly the M2.6 screw was nipped up tight and the stepped section created enough free movement to stop the two outdrives locking up as one. Now I tighted the M3 screw till the diff is tight enough yet loose enough to operate. An M3 grub screw is set into the opposing side tightening up against the main cap head screw and stopping it coming loose.
This has worked really well for me and no issues have come up in this area again.
The culprit. Notice broken section?
- Regular Member
Re: Mustang mod-
[quote="J.M."]Back when Alex ran his Mustang at Knox/Victoria on the day leading up to the enduro we found the rear most part of the chassis spine broke off when it came into contact with the track surface one too many times. Sadly this pretty much rendered the chassis spine useless and a valuable lesson was learnt.
Thats why i made this. Also has a thicker fibreglass bottom 2.4mm
If this would help any one i could make somemore.
- Bormac
Re: PB buggies. Post your pics.
Great mod Mr Strums.
Do you make these chassis plates (MUSTANG) as I know Alex is looking for some
- Regular Member
Well i made the one on this car. Have another one to make for my maxmia next week. just waiting for the postman.
I put two extra bits on the rear as you can see from the carboard template i made up.
- Bormac
Very cool. Mr Incredible_serious is frothing for some of these Mustang chassis. He's a good friend of mine and would really be glad if you could help him out in some way
Thanks for being a part of this thread mate.
Cheers-Jason
Cheers-Jason
- Regular Member
- Regular Member
This is the latest one. An E-bay find. Just wating for parts and should get it finished in the next couple of weeks.
- Bormac
Great find! I know Alex has many MANY PB spares both new and used. No doubt any help you might lend him could result in a few bits and bobs traded in exchange??
- Regular Member
- 1055 Views
Last post by Brandon G
- 535 Views
Last post by Twin Detonator
- 56 Replies
- 5118 Views
Last post by DerbyDan
- 31 Replies
- 5388 Views
Last post by morrisey0
- 1645 Views
Last post by Russ Winn
- 20 Replies
- 3550 Views
Last post by slotcarrod
- 47 Replies
- 10567 Views
Last post by Frankentruck
- 27 Replies
- 14310 Views
Last post by Bob-Stormer
