Has thanked: 1737 times
Been thanked: 1145 times
59burst wrote:Gonzo aluminum parts
small one is DC03 motor bearing dust cover for air supply, and it looks like a cap for stealth
large one is DC01 motor bearing dust cover for standard yokomo, and i'm not sure anything with this
Judging by memory I have that the Air Supply was a motor (as would have been 'Standard Yokomo), I would expect that it's what it says on the header.... a dust cover for the non-pinion end of a motor, to protect the bearing.
Then again, that's just a guess based on logic, not actual knowledge......
Hope that helps.
59burst
Post by 59burst »
Hope that helps.
found some articles about air supply motor along with wimpy-gonzo motors. i'm still not sure with these aluminum caps. but i can remember i saw wimpy motor before. thanks for the info with your opinion :D
Hyeong
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
59burst
Post by 59burst »
aip47-2008 wrote:This is obviously from Thorp. But I have no information from the early item numbers such as this one. Any ideas what this is for?
like this?
http://www.ebay.com/itm/290847077728
aip47-2008
The item is for a ball diff., and more than likely for a Tamiya or Kyosho car from way back when. Just not sure which it belongs! :?
Hcp22
Has thanked: 33 times
Been thanked: 22 times
Post by Hcp22 »
I would put my money on Tamiya from way back and not Kyosho.
Cheers
Lars
My Feedback
if the end is a hex, it's probably the cup drive for a frog/blackfoot thorp ball diff. The one side of the diff had a hex drive(and another larger hex adapter it fit into).
aip47-2008
I have those parts and part numbers. This cup is shorter.
AscotConversion
Has thanked: 43 times
Been thanked: 56 times
Post by AscotConversion »
Hope that helps.
Hyeong
Gonzo / Wimpy was a local battery matcher and motor winder in the Northwest Indiana USA area. I used to get motors and batteries from Lee Morrison, the owner. He wound a lot of mod motors on Air Supply teardowns. This was also the base motor used for a lot of CAM motors as well. I believe they may have also been used by HPI/ Uno at one point as well, but I'm not 100% sure on that. Anyway, I would think that it really is a dust cap for the endbell bearing. Good luck with your research :)
59burst
Post by 59burst »
the HPI/Uno story is awesome even it's not 100% sure. thanks for the info based on your experience :D
V12
Been thanked: 100 times
Post by V12 »
HPI had their own teardowns what also show HPI at the endbell. These were made by Sagami as Yokomo but had better airflow than the Yokomos in my opinion. The only other manufacturer using HPI teardowns for some time had been GM-Racing, at least saw no other until now. I´m not sure but I think I was posting a picture of HPI based GM-Racing motor.
I never saw a HPI motor using Air Supply teardown.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
Ok, here´s a hardball.
SWB Cat clone, who made this?
Ball diffs - two alu rails (like the Optima) sandwiched between two sheets of thin plastic.
Gearbox entirely made of plastic, no alu plates.
Thanks for looking
Gone fishing
civilguy
Has thanked: 5 times
Been thanked: 14 times
Post by civilguy »
like this?
Looks like a Hotshot part to me.
Jeff
transamman908
Post by transamman908 »
Hotshot is #4552. I have a Thorp catalog and this part is not listed in it. Possibly mis-labeled or for an odd ball transmission
Jerzi
Post by Jerzi »
I got pics from the -97 worlds and here is some weird looking car.
Do somebody now what it is.
Yoke maybe.
Jerzi
http://jerryn.kuvat.fi/kuvat/RC.AUTO+KUVAT/TEEMU+LEINO/IMG_1482.JPG
Return to “Identifications”
