My Vintage Box Art RC10 replicas
Ruffy
Been thanked: 66 times
Re: My Vintage Box Art RC10 replicas
Post by Ruffy »
This 3rd labor of love continues forward:
Here is my 3rd Box Art Body work I just got to this point. I'm about 3/4 of the way to completing it, and used an airbrush to do everything you see painted. I still have to do the flat black on the outside surfaces to give it that extra depth, but I also like painting the black on the inside in case the external flat black gets scratched. This 3rd body came out pretty good due to taking my sweet time, but I notice this is taking me longer than usual due to age, eyes, hands and making use of a larger magnifier for fine details. Once I finish the outer flat black surfaces, then I can cut the windows out and she will be ready for the window netting, fog lights, stickers and driver figure.
Ruffy
Post by Ruffy »
Wing now nearing completion; body still requires for me to purchase a flat black for painting the outside black areas.
Ruffy
Post by Ruffy »
Applied the flat black to the exterior surfaces.
Next step is to cut out the windows, then apply nets, lights, stickers...
Ruffy
Post by Ruffy »
Windows cutout now.
Ruffy
Post by Ruffy »
Window Net on the right side finished.
Ruffy
Post by Ruffy »
Window nets and fog lights installed.
Ruffy
Post by Ruffy »
Thursday 9/10/2020 Update:
Driver Figure tiny Team Associated sticker completed.
Pyxster
Has thanked: 11 times
Been thanked: 6 times
Post by Pyxster »
It's probably been asked on here before, but I wasn't having luck in a search. What's the best way to attach the lights to the body?
Ruffy
Post by Ruffy »
Pyxster, The way I do it, is I drill a .08" hole into the body where I want the lights, and then I use 2-56 threaded screws to attach them. The AE fog lights you will need to drill and thread a hole in for the 2-56 screws. If you use the Rough Rider lights as I have here ( the original box art used the Tamiya fog lights, they are larger diameter) then I use a 2-56 hex nut, bonded into the fog light slot, so that it will accept the 2-56 screw.
This picture here of one of my latest builds, Tri-Themed RC10, shows the smaller Associated Electrics fog light from the kit on it. I generally use the AE fog lights on my custom builds, but for the Box Art I use the Tamiya Rough Rider lights and driver.
This is my final "Curtis Edinger" build image, and it has the Tamiya Rough Rider fog lights on it. You can see they are much larger.
Ruffy
Post by Ruffy »
My 3rd Box Art replica is close to completion, I can see the light at the end of the tunnel now.
Pyxster
Post by Pyxster »
As with all your builds, amazing work. :(
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
Ruffy wrote: Tue Aug 25, 2020 6:56 pm Window nets and fog lights installed.
Looking for a source for RC10 Box Art window netting.
Thanks limestang
Been thanked: 3917 times
The net he pictured above was in a Tamiya bag, so likely the hotshot window net. Nitro Master has it. Tamiya USA is oos on just the net (4615002) otherwise it's only $2.30
limestang
Post by limestang »
Perfect - thank you!
azone
Has thanked: 135 times
Been thanked: 115 times
Post by azone »
The Tamiya netting is also used on the Wild One & Wild One Blockhead reissues so should be able to find pretty easily.
Users browsing this forum: No User AvatarFacebook [Bot], No User AvatarMojeek [Bot], No User AvatarTbot [Bot] and 7 guests
