Ten4: the 4WD RC10 project
Been thanked: 3919 times
Re: 4WD RC10 project
I know I am pretty stoked myself!
Peakey
Post by Peakey »
I'm already saving some pennies for this one 8)
Dcast
Post by Dcast »
Just curious guys,are there going to be any issues with the belt clearing/rubbing the battery strap? I know that the Lipo ard cases tend to have a taller profile than the older battery packs. Btw its really exciting to follow your efforts on this project!
The MIP rubbed so this one problem will a little also, but the tensioned side of the belt is the top so it won't be under any real pressures. It will be recommended to cut out the bottom of the battery cup to allow the battery to sit on the chassis.
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Post by mk-Zero »
I'll slip a batter in the mock-up car in the next day or so to see where we are. But just "eye-balling" it without a battery it looks like there will be plenty of space.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
Very nice detail with the built-in tensioner 8)
Gone fishing
mk-Zero
Business Member
Post by mk-Zero »
Bulkhead version 3
I moved the rear guide down more and gave it more clearance with the transmission case, it was hitting on the last version.
I also checked clearance with a battery pack, there was plenty
Getting sooooo close!
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Looking really good and that is probably really close to what MIP could have outed if ever pigs would fly as good as on the Pink Floyd art. Talking clearance it looks like the left battery plug will be challenging to clear or is it the angle of the picture? Good luck with finishing it off!
Come and visit the stable
TomEG
Post by TomEG »
Just to be 100% sure (I'm a RC10 rookie).... It will not be possible to use the A&L Lethal Weapon 2 tranny with this, as the mid gear that drives the belt to the front wheels are just a pulley/guide on the LW2 transmission?
Tom
Correct, stealth only
TomEG
Post by TomEG »
gomachv wrote:Correct, stealth only
Thanks
mk-Zero
Business Member
Post by mk-Zero »
Asso_man! wrote:Looking really good and that is probably really close to what MIP could have outed if ever pigs would fly as good as on the Pink Floyd art. Talking clearance it looks like the left battery plug will be challenging to clear or is it the angle of the picture? Good luck with finishing it off!
Should be okay with low profile battery plugs. I'll try it out.
alien3t
Post by alien3t »
duratrax has a nice set where on the solder area you can solder flat instead of straight in. have them on my 44.2
mk-Zero
Business Member
Post by mk-Zero »
Yup, those are exactly what I'm talking about. AE makes low profile ones too.
1300GT
Has thanked: 486 times
Been thanked: 406 times
Post by 1300GT »
Really awsome work! 8) There sure will be some empty wallets around here when it's finished. :mrgreen:
Chris.
Toys.............they are!
