I didn't realize just how long it has been since I updated this post.
I got into a bunch of Ultimas & Optimas and the Tommy got put on the back burner.
Well, I managed to get the (new) body painted and (finally) got the rims done.
I guess pictures speak louder than words, so I am just going to post pics
I started with a set of Scorpion 2014 rims from Banzai Hobby.
Thanks to ScootMike, I was able to get measurements for the 5 hole pattern.
I masked off the rims and used oven cleaner to remove the chrome paint from the centers
Once the chrome was removed, it was ready to dip dye
(Yeah, don't lift up the rims while the oven cleaner is applied or it will seep under the masking and mess it up)
The only issue I had was the oven cleaner left a residue. Even cleaning them (repeatedly) in dish soap, the dye still did not want to take.
After many dips, the dye finally started to take. So, keep that in mind if you use oven cleaner. It really sucked, but it sure did the trick on removing the chrome paint!
After mounting the tires, I decided that the small area the chrome was removed from wasn't too noticeable. That was the only mess up during the whole process.....I knew something would go wrong, but they look pretty decent. Still have to take a toothpick and clean up around the lettering also. I took these pics while they were still wet.
