Anyone tried this? Yellowed parts white
Re: Anyone tried this? Yellowed parts white
do we know if we need warmer temps to use this method? It is winter here. I get sun but cold inside too.. I have some parts to whiten and wanted to start this week..
- THE H.P FREAK
HI!... Use a UV light with the H/P. It works much better IMO.
THE H.P FREAK wrote:HI!... Use a UV light with the H/P. It works much better IMO.
The beauty of the window sill is IT,S FRREEEEE .99 cents for a bottle of sauce and some patience my lecky bills are astronomical (welder plasma cutter girders
Paul
- THE H.P FREAK
HI!... Well I've done both systems and letting the sun do it, did absolutely nothing IMO. But it has been Winter here. You can position the UV light directly over the bowl so 100% of the UV light hits the parts at point blank range. Plus mine is a florescent U.V light. Barely uses any hydro at all. Been on non stop for 3 months. Hydro bill has stayed the same.
ok i just figured out Ontario Canada LOL the sun only comes out twice a year so each to there own
edit opps forgot the JK
- esaresky75
Going in reverse
Thought I share this photo, all my nylon parts soaking in hydrogen peroxide. This is after I had the front end all cleaned and reassembled then I read the post about whitening the parts. Good practice, I bet I can assemble the front end quicker this time.
Burn more coal - UnderGroundMiners.com
- Alex B
- Has thanked: 23 times
- Been thanked: 46 times
http://retr0bright.wikispaces.com/
and
http://www.amibay.com/showthread.php?t=1480
Gives you instructions and the chemistry on why ABS plastics go yellow with age. The process uses a mixture of hydrogen peroxide and 'oxy clean', which is a U.K stain removing product and UV light.
I haven't tried it yet but it seems to work well on old yellowing computer parts
and
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
What I'm eager to see this tried on are all the Tomy robots from the 80's as this happened to them with age as well.
- victor_cathedral
super nintendo's also suffer badly from this. so did transformers
- GJW
just read both the wiki and the forum what a cool write up, what you you guys in the states class as oxy? any pics. keen to find a similar product here in aus.
Based on the pics on the recipe page http://retr0bright.wikispaces.com/Retr0Bright+Gel NapiSan (the pink one) would work for the oxy booster.GJW wrote:just read both the wiki and the forum what a cool write up, what you you guys in the states class as oxy? any pics. keen to find a similar product here in aus.
- dave00beer
- Has thanked: 9 times
I do recall reading up on the "retro bright" formula awhile back when whiting parts from my old Traxxas Hawk. Never used the recipe, but I had great results using a volume 30 peroxide used for hair bleaching (bought at a beauty supply store) Now this was done outside using the sun.
Now with my RC10T, being winter still here and crappy weather I did the UV bulb indoors. UVA bulb (non-fluorescent) to be exact.
These are the results from the other day, this was just using the brown bottle 3% H2O2 thats available @ your drugstores, etc.
It worked out great, more time consuming then the natural sun IMO (although I did use a lot stronger peroxide outdoors so hard to tell) This was 22-26 hrs of soaking with the UV lamp. Parts were pretty yellowed.
You can see some of the before pics in my thread in the RC10T section.
- Lowgear
All these parts look incredible but I don't think they were ever stark white like this from Associated were they? So if you're doing it for a box build type restoration its incorrect. When I do mine I'm going to take them out before they get too white.
- Has thanked: 36 times
- Been thanked: 1319 times
that's correct. none of the associated parts were EVER as white as guys are making them now. some of the yellowest parts i've ever seen were brand new in the package.
- 2890 Views
Last post by JekyllnHyde
- 41 Replies
- 4953 Views
Last post by SmallScaleSmitty
- 1302 Views
Last post by badhoopty
- 1164 Views
- 1434 Views
Last post by treehugger
- 792 Views
- 1046 Views
Last post by shirochanwrx
- 2042 Views
Last post by THE H.P FREAK
