Progress On My BBT Sprintcar
tizeye
Re: Progress On My BBT Sprintcar
Post by tizeye »
Cheers guys I really appreciated your input..tires are a problem, I was told by the manufacturer that there are custom works tires that will fit..trouble is I can't find any..they also said Losi Slider tires will fit so I've ordered a set..I guess foam could be an option..I've put Hot Trick on my search options on ebay as well..thanks again..
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
Don't think the Losi Slider tires are gonna work for you. They need a groove to glue to or at least set in. They are wide though. What wheels are those? They look like they are gonna need some foam donuts...
tizeye
Post by tizeye »
klavy69 wrote:Don't think the Losi Slider tires are gonna work for you. They need a groove to glue to or at least set in. They are wide though. What wheels are those? They look like they are gonna need some foam donuts...
Yeah I thought that might be the case..the wheels are from http://www.rdent.com/sprint/sprintparts.html there are some pictures there of tires mounted on rims are they Slider tires?..I can't understand why someone would make rims that you can't get tires for..I asked them before I purchased them what tires fit it they said Street Works (which one) and Losi Slider (1/10)...anyway if all else fails foam it is..
well, the rims you have on the back of your car are for foams. there's no lips for a rubber tire bead to sit in.
you should've got the tires you wanted first. then, got the correct size rims to put them on. these would require a 2.0 x 1.0 front rim, and a 2.0 x 1.5 rear rim.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRYG2&P=SM
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXRYG3&P=SM
i don't know what size rims would be needed for the losi slider tires.
tizeye
Post by tizeye »
scr8p wrote:well, the rims you have on the back of your car are for foams. there's no lips for a rubber tire bead to sit in.
Thanks for that I guess I just loved the look of those alloy rims so much I just had to have them..Oh well
tizeye
Post by tizeye »
Just made myself an alloy front shock mount...what do you think..a bit more polishing and it should look OK..
klavy69
Moderator
Post by klavy69 »
The Losi Slider tires you mention are 2.0 size...a great addition to the 2.0 vintage stock of street/oval type tire for looks but wierd in the fact they released these in that size with only one other tire they still produce to fit the rears of these...maybe a prequel to more tires to choose from if these sliders take off. links to rear and front tires:
http://www.rcboca.com/rear-tire-pr-slider.html
http://www.rcboca.com/front-tire-pr-slider.html
tizeye
Post by tizeye »
klavy69 wrote:The Losi Slider tires you mention are 2.0 size...a great addition to the 2.0 vintage stock of street/oval type tire for looks but wierd in the fact they released these in that size with only one other tire they still produce to fit the rears of these...maybe a prequel to more tires to choose from if these sliders take off. links to rear and front tires:
Thanks Todd they look really sharp...
Pete
railey72
Post by railey72 »
Pete,
Nice work so far on the sprint, looks killer!!
I am building a few sprints right now and have had the same issues with tires that you are having. The old kyosho sideways tires are cool if you can find a set (long discontinued). The rears are the correct size for these and Advance wheels (2.0). Otherwise, I also ordered a set of losi sliders and I think they look really good mounted. They will work great for a shelf sprint to get a good realistic look. I will try and post some pics later tonight of the different options I have found.
tizeye
Post by tizeye »
railey72 wrote:Pete,
Yep mine will be a shelfer so I'm only after the right look...if you know what I mean..I have some sideways tires and they are a different diameter than the rims I have...if you are after a set (see Pic) let me know and I'll list them in the buy/sell section....there is a 4th wheel I just need to find it.. :mrgreen:
Looking forward to seeing some pictures of your sprinters..
Pete
railey72
Post by railey72 »
Here are some of the options I have found so far. Losi slider tires, advanced grand prix and slicks, kyosho sideways, proline 2.0 strikers.
fastang
Post by fastang »
Bottom picture, back row, second from left-what are those? The first one in that row looks good too.
Thanks
tizeye
Post by tizeye »
railey72 wrote:Here are some of the options I have found so far. Losi slider tires, advanced grand prix and slicks, kyosho sideways, proline 2.0 strikers.
Very nice..can't wait to see the cars...these sprintcars are addictive almost bid on a bunch of 3 on ebay today..went for just over $200 I think..not bad..
klavy69
Moderator
Post by klavy69 »
fastang wrote:Bottom picture, back row, second from left-what are those? The first one in that row looks good too.
Thanks
don't know what the second one in is but the first one is the Losi slider tire. For looks that second tire looks cool...kinda like a hoosier.
mrlexan
Post by mrlexan »
Dang it Doug, stop with the eye candy pics already. You are as bad as Techna-Jim. :mrgreen: :mrgreen:
www.gojammedia.com
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarMojeek [Bot] and 6 guests
