JRX2
- Brandon G
Re: JRX2
http://cgi.ebay.com/TEAM-LOSI-JUNIOR-TWO-TIE-ROD-LINK-SET-A-4050_W0QQitemZ350102712550QQcmdZViewItemQQptZRadio_Control_Parts_Accessories?hash=item5183bf70e6&_trksid=p3286.c0.m14
If you want oe parts you can't beat the price. Yes turnbuckles are easier, but they will also cost a bit more.
- Has thanked: 4 times
Re: JRX2
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Re: JRX2
I like to fit atleast one plastic servo post to any steering servo I have to stick down with double sided tape. I'll drill an extra hole in the chassis if there isnt one and countersink it. Make certain you clean both the servo and chassis areas you will be attaching the double sided tape to so that you get the best possible adhesion. Oil residue, dust etc... will foul the adhesion properties of the tape so I use either motor cleaner spray or the like to prep both surfaces. Make sure you have a servo saver fitted to the servo and this should keep you out of trouble.
Re: JRX2
I used to use servo tape only and it worked fine. I good name brand servo tape will work ,the Bolink was always good to me and it usually came of well( in a few pieces instead of separating and then picking at it ) but on that chassis you can use and associated B4 mounts if you want to drill the chassis.
Racin since 1987
Re: JRX2
project is coming along nicely for my first attempt at restoring a car...will have to pick up a shell for this one and stash her on the shelf...i would like to thank anybody who offered any help/ advice...have just about enough parts left over for a runner...can anybody suggest a driveshaft for me??? you guys are great
- RedScampi It’s my birthday!
Re: JRX2
Looks great! I like the natural wheels. You don't see them much. Get a body from Mr. Lexan. Pricey but perfect. I got a bluegroove body and it's of dissappointing quality.
Gary
- mrlexan
- Been thanked: 12 times
Re: JRX2
The pricey side...... I don't think they are pricey, not for what you get. Quality, no shatter concerns like TBG, window masks, and overspray film, and all three pieces: wing, gear cover, and body.
www.gojammedia.com
www.gojammedia.com
Re: JRX2
Can't say about the TBG version, but the Mrlexan body is tough. I beat the heck out of mine at the vonats this year. quite durable, much better than the original shells I've used.mrlexan wrote: no shatter concerns like TBG,
Re: JRX2
Bodies are just pricey in general at least for me. I have several cars that need bodies but i keep putting it off because of the cost. Maybe I'm just whining or maybe I'm just too poor for this hobby.mrlexan wrote:The pricey side...... I don't think they are pricey, not for what you get. Quality, no shatter concerns like TBG, window masks, and overspray film, and all three pieces: wing, gear cover, and body.
Gary
- mrlexan
Re: JRX2
One of the boys down under, I think it was Jamesaconsola wrote:Can't say about the TBG version, but the Mrlexan body is tough. I beat the heck out of mine at the vonats this year. quite durable, much better than the original shells I've used.mrlexan wrote: no shatter concerns like TBG,
www.gojammedia.com
www.gojammedia.com
- 3977 Views
Last post by DerbyDan
- 30 Replies
- 4424 Views
Last post by markbt73
- 1334 Views
Last post by Synergy
- 1255 Views
- 1456 Views
Last post by bearrickster
- 53 Replies
- 4223 Views
- 2042 Views
Last post by aconsola
- 1188 Views
Last post by Toyotachris1982
