'85 Gold Pan Resto-Mod...Need Some Advice Here!
Re: '85 Gold Pan Resto-Mod...Need Some Advice Here!
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
I sent a pm with a scan of the template if that won't work I gave you info on how to get the real thing from me. Also you may want to learn about fitting the later Slipper assembly from I think a b3 or 4 and that would be an excellant hop up for the extra power.
This is all very interesting!
- PBR Allstar
a01butal wrote:I sent a pm with a scan of the template if that won't work I gave you info on how to get the real thing from me. Also you may want to learn about fitting the later Slipper assembly from I think a b3 or 4 and that would be an excellant hop up for the extra power.
[/quote]DV8ion wrote:Yup I did make the switch over to the B4 spur/slipper combo and it works amazingly. All you need is a few parts and your good to go.
Heres a list of parts you will need to make the switch.
As for using a complete B4 Stealth.....it won't work without alot of modding to both the tranny case and your chassis. You can still use your stock gear cover on this conversion......all you have to do is make sure you setup your slipper and then just mark and Dremel the excess off the top shaft end.
- Spur gear 81T (9651)
Slipper hub (9604) x2
Slipper pads (9603) x2
Top Shaft (9601)
Slipper Spring (9605)
Slipper locknut (6629) or a 5-40 locknut
Heres a pic of what it ends up as.
here's the info on using the later B4 slipper setup on a first generation 2.25 stealth trans
- Been thanked: 5 times
Do you think you could send that to me also? Please.a01butal wrote:I sent a pm with a scan of the template if that won't work I gave you info on how to get the real thing from me. Also you may want to learn about fitting the later Slipper assembly from I think a b3 or 4 and that would be an excellant hop up for the extra power.
Actually, I just realized I have an old 10T chassis I can use. Thanks anyway.justinspeed79 wrote:Do you think you could send that to me also? Please.a01butal wrote:I sent a pm with a scan of the template if that won't work I gave you info on how to get the real thing from me. Also you may want to learn about fitting the later Slipper assembly from I think a b3 or 4 and that would be an excellant hop up for the extra power.I want to put a stealth in my graphite runner. The only thing that's keeping me from doing now is drilling the holes. I'm sure I could do it without the template, but it would be nice to have it.
- a01butal
justin, just sent a pm with the template scans. Looks like you may not need them but it can't hurt to have some frame of reference.
- 737 Views
Last post by jeepy2013
- 2623 Views
Last post by fredswain
- 2301 Views
Last post by Dave145
- 1965 Views
Last post by Bottom Feeder
- 1122 Views
Last post by variant45
- 2385 Views
Last post by JPAE07
- 1283 Views
Last post by Brandon G
- 2537 Views
Last post by Benjammin
