need help
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: need help
Rick, I will get the 10T and 10 manuals from that link and print them up for you. They will be in the box.
- Been thanked: 81 times
Re: need help
I used the same carriers. I may be wrong but you can use axle set ups from the early to the b4 the lengths are the same. You may have to use axle shims to get the correct spacing. If Iam wrong some will reply with the correct info.bearrickster wrote:Did you have to change the carriers?
- bearrickster
Re: need help
JK your are simply the best Thank youJK Racing wrote:Rick, I will get the 10T and 10 manuals from that link and print them up for you. They will be in the box.
- highwayracer
- Been thanked: 6 times
Re: need help
hello Rick,
The original carriers on the RC10 used a flanged bearing (1/4 inch axle). If you switch to the newer style axle, you'll have to replace the bearings. The carriers are drilled straight though and do not have an inner lip. So if you put a regular unflanged bearing in the original rear carrier, the bearing will just slide out.
You have 3 options:
1. Find the correct flanged bearing (difficult)
2. Replace the carrier with the type used on the rc10t
3. Use the original carrier and bearings, but make a sleeve to fit over the axle to increase its diameter.
hope this helps...
Roger
You have 3 options:
hope this helps...
Roger
- JK Racing
Re: need help
http://www.avidrc.com/shop/?action=item&id=88&prevaction=category&previd=1&prevstart=0highwayracer wrote:1. Find the correct flanged bearing (difficult)
$1 each, reasonable shipping too.
- bearrickster
Re: need help
That would be for the carrier bearing?Or the one that goes into the wheel or is it both?JK Racing wrote:http://www.avidrc.com/shop/?action=item&id=88&prevaction=category&previd=1&prevstart=0highwayracer wrote:1. Find the correct flanged bearing (difficult)
- PBR Allstar
Re: need help
that's the one that goes in the carrier, I think it goes in the early jellybean wheels too.
Re: need help
PBR Allstar wrote:that's the one that goes in the carrier, I think it goes in the early jellybean wheels too.
so far every stinkin rim I have come accross takes that exact size. People keep telling me the bearing size is the same as the rc10t but I have not come accross one set of rims that takes those for the RC10. maybe they exist, i just haven't got any in the lots Ive purchased.
Re: need help
highwayracer wrote: 3. Use the original carrier and bearings, but make a sleeve to fit over the axle to increase its diameter.
Roger
- PBR Allstar
Re: need help
RC Chick wrote:PBR Allstar wrote:that's the one that goes in the carrier, I think it goes in the early jellybean wheels too.
I just went out to the garage and checked, my C.E. that has 2" three piece wheels on it and it takes the 3/8" by 3/16" plain bearing. Sounds like the lots you've been getting have a lot of old wheels in them!
- Has thanked: 36 times
- Been thanked: 1318 times
Re: need help
this bearing is used only for the buggy rear hub carries. they would replace the original 1/4 x 3/8 bearing so you can use a 3/16 axle to run modern 2.2 rims.RC Chick wrote:That would be for the carrier bearing?Or the one that goes into the wheel or is it both?JK Racing wrote:http://www.avidrc.com/shop/?action=item&id=88&prevaction=category&previd=1&prevstart=0highwayracer wrote:1. Find the correct flanged bearing (difficult)
the front bearing size for the the old rc10 buggy rims (1.9 3 piece jelly bean, 2.1 tq) is 3/16 x 5/16 flanged. the 3 piece front c.e. dish rims are 3/16 x 3/8 plain.
- bearrickster
Re: need help
How about some pic's of some cool upgrades for a goldpan? I dont know what I am going to doI just want something different but nice and Most of all that will run nice
Re: need help
there's a reason this was his 3rd option. mainly because it's not the best one.MONSTER wrote:highwayracer wrote: 3. Use the original carrier and bearings, but make a sleeve to fit over the axle to increase its diameter.
RogerI wanna hear more about this.
Re: need help
the front bearing size for the the old rc10 buggy rims (1.9 3 piece jelly bean, 2.1 tq) is 3/16 x 5/16 flanged. the 3 piece front c.e. dish rims are 3/16 x 3/8 plain.[/quote]
Well that would be why then thats all the rims I have jelly bean and tq's. I can't find the thread that tells you how to convert to modern wheels, i searched and searched where did it go?
Users browsing this forum: Bing [Bot],
Yandex [Bot] and 4 guests
