What was old is… still old, but a lot newer (Update 2/20/11)
wyldbill
Re: What was old is… still old, but a lot newer
Post by wyldbill »
i don't know the CW part number though. i'd have to look for it.
Custom Works has 2 styles one is like original Losi, and the other is flat on top for vertical camber link mount but they both have the same part #3241.
Has thanked: 356 times
Been thanked: 470 times
The ones listed are repackaged Losi LOSA2038's. They're my favorite DO rear hubs.
Losi also makes a new vertical mount hub, with fore & aft adjustments to eliminate camber link binding for the xxx series.
aeiou
Post by aeiou »
bngiles wrote:Which rear arms did you use? Also, what is the p/n on the RPM rear hubs?
Looks great by the way...
Here's a link for info on those arms:
http://www.rc10talk.com/viewtopic.php?f=1&t=3266
The RPM hubs are part #70272:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXEU81&P=7
And some bearings for those hubs that work with the B4 axles (I used the revolutions with the rubber seals removed):
http://www.avidrc.com/shop/?action=item&id=117
http://www.avidrc.com/shop/?action=item&id=102
And thanks :D
popboy905
Been thanked: 10 times
Post by popboy905 »
I want to make sure i have this clear, Klein arms (as replace for rpm worlds backend) with b4 carriers and cvd will mount up on a tub chassie (not cut down for rpm worlds conversion) and will keep the correct rear end spacing and allow you to use b4 rims and tires? If so that is so dialed!!!! Also what rims are those on the B4 in the picture?
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
JConcepts Rulux Wheels....I love 'em.
aeiou
Post by aeiou »
popboy905 wrote:I want to make sure i have this clear, Klein arms (as replace for rpm worlds backend) with b4 carriers and cvd will mount up on a tub chassie (not cut down for rpm worlds conversion) and will keep the correct rear end spacing and allow you to use b4 rims and tires? If so that is so dialed!!!! Also what rims are those on the B4 in the picture?
All of what you said, with the exception of the B4 rear carriers. The B4 carriers with this configuration didn't provide the correct spacing for the CVDs. So far only the RPM #70272 and AE #7358 RC10T hubs have worked for me. As mentioned earlier in this post, the Losi/CW hubs are a possibility as well.
Like JK said, JConcepts Rulux wheels. They will be on my runner version, too. 8)
aeiou
Post by aeiou »
Well, here's the runner so far... I installed the RPM tranny conversion & T3 slipper on this one. There are 1.32" shocks on boths ends right now - I may swap the fonts for the 1.02", depending on what happens when I start tuning the suspension. I'll post some more pics once I get the electronics and body installed.
Really looking forward to getting this thing dirty! :D
Brandon G
Re: What was old is… still old, but a lot newer (Updated 5/15)
Post by Brandon G »
Which body are you leaning towards?
Dr. Robotnik
Post by Dr. Robotnik »
So cool! It's awesome to see people making these competitive again.
aeiou
Post by aeiou »
The runner is done. Well, almost... I still need to put a better servo in it, add the LiPo cut-off and drill and tap a new hole for the lower gear cover screw. But it’s done enough to get in a test run or two.
As I suspected, I ended up with the 1.02” shocks in the front. I’m not sure who makes the body (JConcepts, maybe?). It came with a B4 lot, already painted and just slightly used. Since it sort of fits the theme, I thought I’d try it out on this build and it ended up fitting pretty well (where would we be without Velcro?).
I hope to get this to the track over the next couple of weeks. I’ll follow up with some more photos of the track session (dirty pictures :lol: ).
kaybo19114
Re: What was old is… still old, but a lot newer (Updated 5/19)
Post by kaybo19114 »
That looks awesome...
just gotta ask - what wheels are on it?
PottBelly's R/C Raceway (RIP) | Team Tekin | GQ Tires | Slingshot Batteries | Banzai Motors | Team Psycho Cells | Exotek Racing | Team Belly
I like you. You remind me of when I was young and stupid :cool:
aeiou wrote:Like JK said, JConcepts Rulux wheels. They will be on my runner version, too. 8)
kaybo19114 wrote:just gotta ask - what wheels are on it?
too busy looking at the pics, huh? and you say you subscribe to PLAYBOY only for the articles. :wink: :P
MOmo
Post by MOmo »
Thats Sexy!
Now i need to look around and start scrounging parts to make one.... or perhaps work on my graphite edition to make the same thing!
Nice work.
MOmo
mrlexan
Post by mrlexan »
I have really dug those wheels since I first saw them on the World's internet coverage on Oople. Looks great!
www.gojammedia.com
Brandon G
Post by Brandon G »
Which BL motor do you run in it, and what pinion spur did you end up using?
