Team Mooh at the german regionals 2008
- siebenelch
- Been thanked: 4 times
Re: Team Mooh at the german regionals 2008
Sebastian did some other nice shots of my car.
Enjoy!
Michael
Enjoy!
Michael
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Did you like the handling of the car with Schumacher MiniPin? I also run on grass at my local club and every single driver uses Mini Spikes, hence my question... have you ever tried them too to compare?
Come and visit the stable
- Minicooper 35
Problem is: in Germany the Mini-Pin is one of the controlled 2WD tyres. Others are PL Hole-Shot, Panther IforgotTheName and LOSI X-2000.
I know that in the UK the Schuey Mini-Spike and the Ballistic tyres are used and should work much better.
"The things you own, they end up owning you."
- Asso_man!
OK, I understand now! Mini Spike tires surely do work better, when the grass is wet the mini pin ones must be a real nightmare!
- Minicooper 35
They are! In the morning when the grass is wet you can dump the first qualifyer because of the lack of grip. The 4WD's are allowed to use LOSI Studs which helps a lot but in 2WD we only can use Hole-Shots or X-2000 - no good sustitutes ...Asso_man! wrote:when the grass is wet the mini pin ones must be a real nightmare!
- Asso_man!
that is really ridiculous, where's the fun if you can't use tires that suit the track?
- Minicooper 35
That's the problem with restricted tyres. I haven't run the Mini-Spike yet but the Mini-Pin do not work so bad to be honest. They become a bit tricky when the grass is fresh or starts to wear out but in the inbetween-conditions they work aweeesome.Asso_man! wrote:that is really ridiculous, where's the fun if you can't use tires that suit the track?
Thanks!! I think I have something to read at work todayMinicooper 35 wrote:Hi dude,kaybo19114 wrote:was it difficult to use the B4 slipper on the car?? And it is a "direct" bolt-on kind of thing
just take a look here.
http://www.rc10talk.com/viewtopic.php?p=13007#p13007
As Michael said it is very easy to do and works perfect. After initial setup I did not had to do any adjustments.![]()
Seb
PottBelly's R/C Raceway (RIP) | Team Tekin | GQ Tires | Slingshot Batteries | Banzai Motors | Team Psycho Cells | Exotek Racing | Team Belly
I like you. You remind me of when I was young and stupid
- 976 Views
Last post by terry.sc
- 705 Views
Last post by call-911
- 736 Views
Last post by GJW
- 33 Replies
- 5653 Views
Last post by mrlexan
- 1942 Views
Last post by limestang
- 713 Views
Last post by Toaster
- 1401 Views
Last post by templeofspeed
- 300 Views
Last post by GrePo
Bing [Bot],
Semrush [Bot] and 4 guests
