Anyone have a "magic sauce" for servo tape removal?
BattleTrak
Has thanked: 1154 times
Been thanked: 624 times
Re: Anyone have a "magic sauce" for servo tape removal?
Post by BattleTrak »
RogueIV wrote: Wed May 14, 2025 10:39 am
BattleTrak wrote: Tue May 13, 2025 8:55 pm I use regular naphtha/zippo lighter fluid.. let it soak in, then scrape off with a plastic razor blade or your fingernail.. It’s great for cleaning a lot of other things off too and doesn’t attack paints. Goo-Gone/Goof Off works too, but is really hot and will remove paints and attack plastics.
goof off and goo gone are 2 completely different animals. I personally haven't had an issue with goo gone (the citrus one) but I wouldn't use it on anything painted.
Goof off I'd stay away from personally, too aggressive.
WD-40 often works well enough and who doesn't have a can of it laying around?
My mistake.. thought they were the same. Goof off is definitely the one you have to be careful with.
-Brad
1911Colt
Has thanked: 1791 times
Been thanked: 868 times
Post by 1911Colt »
PB Blaster works very well, too. Be aware that it was apparently intended to be applied from across the room. :lol: Every can I ever had was pressurized to about 1 million PSI, like Hornet spray. :lol: I spray it into a towel and wipe it onto the part, or cover the part with a towel before spraying, otherwise it goes everywhere.
Regardless of the chemical you use, a purpose built plastic scraper is an excellent tool to have. I used to repair credit card terminals for a living. Those things always have stickers all over them. Goo Gone and a scraper is all we ever needed.
Has thanked: 2620 times
Been thanked: 2990 times
1911Colt wrote: Wed May 14, 2025 11:14 am Regardless of the chemical you use, a purpose built plastic scraper is an excellent tool to have.
I use Goo Gone with plastic razor blades and have good results. The scraper is a key item to have.
Has thanked: 273 times
Been thanked: 2109 times
R6cowboy wrote: Tue May 13, 2025 9:00 pm Goo-gone is nuclear sh!t, has no business being used for anything r/c related in my opinion. I'll never make the mistake of having that stuff in the r/c room again and accidentally using it.
Edit: My mistake, I was thinking Goof Off, not Goo-Gone.
The bottle of Goof Off that I have is just acetone (I think there is a few versions). Cheaper to get the big cans in the paint department.
The vapor is rough but it dissolves CA glue. It's safe for nylon parts but will dissolve regular plastic.
