Outlaw Rampage Pro Team - electric conversion rescue
- Has thanked: 38 times
- Been thanked: 18 times
Re: Outlaw Rampage Pro Team - electric conversion rescue
Any recommendations for spur gears? The factory 105t is for the 30k rpm .12 OS and is geared too low for my brushed electric setup. I think I need something in the 75-86t range but I am not sure what will fit.
Making some progress. Got a new motor and I was able to figure out the transmission except for one item. The spur gear wobbles however the driveshaft does not appear bent. I think it is related to how the inside slipper plate rests on the pin but I am not sure. The wobble is enough that the mesh is perfect for about 2/3 of the rotation and then tight on the remaining third. Obviously not ideal, but not sure how critical this is.
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2092 times
If you can find a 32 pitch spur gear that will fit, I'd switch to it. The larger gears are much more forgiving on mesh.
New driveshaft fixed it. I will keep that in mind though. I do have a Mod 1 gear and it is way too big. 32p might work.juicedcoupe wrote: ↑Wed Jun 04, 2025 4:53 pm If you can find a 32 pitch spur gear that will fit, I'd switch to it. The larger gears are much more forgiving on mesh.
- 23 Replies
- 4194 Views
Last post by Rider400
- 1152 Views
Last post by Michaels tc
- 776 Views
Last post by Elkcycles
- 56 Replies
- 5376 Views
Last post by R6cowboy
- 197 Views
Last post by RC10th
- 2596 Views
Last post by Marshky
- 88 Replies
- 16689 Views
Last post by KidAgain
- 1868 Views
Last post by purpletimbo
