** Hopelessly Incomplete Project of the Month - May 2025 **
When you need an answer via votes.
Vote for your top 2 Hopeless Build choices
Poll runs till Fri May 30, 2025 2:10 pm
Elkcycles
3
9%
Trass
7
22%
RogueIV
0
No votes
BattleTrak
12
38%
16%
GrePo
1
3%
Scottzone
4
13%
Total votes: 32
R6cowboy
Has thanked: 842 times
Been thanked: 880 times
Re: ** Hopelessly Incomplete Project of the Month - May 2025 **
Post by R6cowboy »
Frankentruck wrote: Sat May 10, 2025 8:06 pm Next month will be back to 'junkiest runner' and then probably back to hopeless builds again. I would take other suggestions too.
When I look at BattleTrak's JRX2, it makes me wonder how many he's trying to build from that pile of parts 😂
Scottzone also has potential for junkiest build for an otherwise decent truck because of the poorly made gearbox. At least my TRX1 has *some* hope of getting a good gearbox setup. Are there some SST gearboxes that work smoothly? How would someone know other than trial and error?
Gonna be boxing up all rc stuff in a couple months due to moving soon, all the way across the street. Bought the neighbor's house straight across from my living room window. Been waiting 2-3 yrs for them to finally let it go, love it. So I won't be surprised if I don't touch anything rc til mid-late fall :(
For some strange reason the SST gearbox in my Pro-XRT is very smooth. I did follow stickboy007's SST pointers, so that likely had something to do with it.
-Jerry-
Scottzone
Has thanked: 18 times
Been thanked: 14 times
Post by Scottzone »
R6cowboy wrote: Mon May 12, 2025 7:52 pm For some strange reason the SST gearbox in my Pro-XRT is very smooth. I did follow stickboy007's SST pointers, so that likely had something to do with it.
I still have some things left to try. To summarize his pointers:
1. Leave the case screws loose.
2. Leave one of the two bearings out of the middle of the output gears.
3. Add a small washer to the thrust bolt so it does not hit the far side of the case when tightened down.
4. Upsize the driveshaft bearings and run a tighter mesh.
Am I missing anything?
Return to “Polls”
