MIP cable kit RC10
eddy
Re: MIP cable kit RC10
Post by eddy »
The parts are mine the diff will go in the car and the two smaller gears and just a sample on what I'm looking to get the right gears for the front gearbox
eddy
Post by eddy »
eddy
Post by eddy »
The parts are mine and the rear diff 40t is going in the car but the two smaller gears are just a sample on what I'm looking for the front gearbox
RogueIV
Has thanked: 1926 times
Been thanked: 952 times
Post by RogueIV »
Best bet is open the rear transmission and get a count on gears in there. Looks like the front case you have may use the same gears as the rear, which would make sense since it should be the sam ratio.
Phin
Has thanked: 82 times
Been thanked: 235 times
Post by Phin »
I don't know if the replica MIP rear transmission is the same as the original but if so it's a 2:1 ratio and used metric Mod .6 gears (40t diff + 20t top gear)...same as the ones used in the Tamiya SRB trans. The original front 4wd gearboxes used different gears (30t diff + 15t top) but I'm not sure if they were the same module/pitch gears as the rear. Again, don't know if the 3d printed replica used different gears.
Users browsing this forum: No User AvatarAmazon [Bot] and 6 guests
