Since I started to digg in the Lynx, it was now time to get into it, for real.
I disassembled the front gearbox to see what was inside...
I started to reproduce the gear set. Gears are module .8 (11T/30T), and bevel gears are 12T module 1 (the same are used at the rear). The most difficult was to find the module, and the bevel gear definition (but again, not my firsts, and once you have the right module, and the cone, this is easy, specially when they are like this).
The front of the gearbox is a derived of the front end of the 2WD version...
The position of the shaft center is also used to define the position of the main gear, using center distance and one measure taken on the part...
I then did the same work at the rear...
And we have the full transmission in for the 4WD version
I cheated a bit for the 4WD assembly as I just pull my transmission, hiden the 2WD parts, then one single joint, plus the change of the front wheels, shaft and dogbones addition and boom, voilà..
The front wheels have one ways since there is no diff. For the sake of mentionning it, there is no one way of the proper dimension in the database within Fusion, so I just figured out a arrow on a extruded part to figure it out (we don't see it anyway, but that's for the sake of saying there is some oneways in the front wheels)... WHile having the car in my hand, also went in the kitchen to weight the car : 1000g without steering servo, RX, ESC and bodyshell... it may be lighter than the Marui Samurai...
