Another Meteor
- Has thanked: 2759 times
- Been thanked: 2250 times
Re: Another Meteor
Found a cool old wing to finish off the runner body and an old Demon motor I thought was toast but it turned out it was a bad brush and brush spring , also swapped out the 12t pinion for a 14t and it runs very nicely now with the motor still only warm after 5 min . Last thing to do now will be the gearbox support motor bracket .
I've got a Novac Super Rooster in there so the Novak decals at least are valid .If a jobs not worth doing then its certainly not worth doing well.
Re: Another Meteor
Last piece of the puzzle, motor plate/gearbox brace , I found a little time to make it today .
Re: Another Meteor
I've been working on lowering the body down , firstly with the rear shock tower I've lowered the body 10mm at the rear , the front is harder as the servo saver is very tall and it limits how far the front can be lowered so I had a plan
I decided to make a bonnet bulge above the servo saver
so using wet tissue in a circle around where I wanted the bulge I heated the body with the reflow tool in my solder station , its basically a small hot air gun , then when the ABS started to soften I pushed the rounded end of a tool handle up from the inside and held it till it cooled. Worked pretty well
Then it was just a matter of trimming the body to the right lines , I've not done the windows yet .
- Regular Member
- Been thanked: 5 times
Re: Another Meteor
Nice job.
I wish I had a set of axles that worked on the new wheels without effort
If you can post a pic of exactly what you did to make the rear wheels fit & a description I'd be interested. I am going to hex wheels because I couldn't get the mardave ones to fit right.
- 6352 Views
Last post by DerbyDan
- 63 Replies
- 10840 Views
Last post by Darkmard
- 2658 Views
Last post by chevron
- 2675 Views
Last post by Dadio
- 4812 Views
Last post by LurkingCAT
- 56 Replies
- 16789 Views
Last post by cunawarit
- 2946 Views
Last post by Miggers
- 2397 Views
Last post by Frankentruck
