Derustification the Frankentruck way
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Re: Derustification the Frankentruck way
Post by BattleTrak »
Great tutorial! Thanks!
-Brad
TokyoProf
Has thanked: 563 times
Been thanked: 418 times
Post by TokyoProf »
Thank you for this very helpful post! A few questions from above...
1) So the bluing actually turns out black correct? This is the look I prefer anyways.
2) What kind of oil did you use for the metal parts after derusting?
3) Vinegar is effective for rust removal, but why only 20%?
bonus question
4) Any way to keep vanilla white nylon from becoming yellow over time?
Thanks!
Has thanked: 2605 times
Been thanked: 2979 times
The bluing fluid is actually a blue tint out of the bottle. The steel ends up with a black oxide protective coating.
I used light weight 3 in 1 machine oil, like is used for sewing machines and general mechanism lube.
Somebody else will have to go over the vinegar question, but it's probably for the same reason that Coca Cola is said to be a good rust remover, the weak acid content.
I'm no good managing white nylon. Can't help with that.
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Post by TRX-1-3 »
TokyoProf wrote: Tue Dec 05, 2023 7:53 pm
bonus question
Thanks!
I really think the only way is to keep it from UV exposure and air contaminates (smoke/oils [don't store it on top of oven hood vent while smoking Lucky Strikes and pan-frying bacon]). Then it's just a matter of careful disassembly, whitening with peroxide, and reassembling if the yellowing becomes "unacceptable".
Users browsing this forum: No User AvatarBing [Bot], User avatarDirtburner, User avatarjuicedcoupe and 2 guests
