RC10 Retro Racer
- Jeep-Power
- Has thanked: 56 times
- Been thanked: 52 times
- Jeep-Power
Re: RC10 Carpet
Took it racing this past weekend. TQ'd the 2nd quali, started 2nd in the main , but ran out of tires and talent. My podium mates drove impeccably, to boot.
Had a blast racing it, for the first time.
Need to build some adjustability into the suspension.
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: RC10 Retro Racer
If using the GT/DS servo saver with the nose plate in the long wheelbase configuration, you should attach the bellcranks/servo saver to the front holes (you might have to tap them, 8-32). Then use 1/4" (100*) screws to attach the nose plate to the chassis.
- Has thanked: 1782 times
- Been thanked: 859 times
Re: RC10 Carpet
The photo I want to see is your super cool retro buggy with all of the modern stuff you beat.Jeep-Power wrote: ↑Thu Sep 05, 2024 10:31 am Took it racing this past weekend. TQ'd the 2nd quali, started 2nd in the main , but ran out of tires and talent. My podium mates drove impeccably, to boot.
Doing some quick math and knowing the size of an RC10, I am thinking you are approximately 8 foot 3. Is that about right?
- Jeep-Power
ahhh-- this will probably improve the steering geometry significantly. thank you!juicedcoupe wrote: ↑Thu Sep 05, 2024 11:18 am If using the GT/DS servo saver with the nose plate in the long wheelbase configuration, you should attach the bellcranks/servo saver to the front holes (you might have to tap them, 8-32). Then use 1/4" (100*) screws to attach the nose plate to the chassis.
- Jeep-Power
Re: RC10 Carpet
that will be a good photo -- next time! With that said --the heat was all rear-motor cars.
haha -- close. 6'6"
- Jeep-Power
Had this buggy and the B44.3 out at a friend's backyard clay track this weekend. Making the triple was not possible with this car, but the double was doable, sometimes. Had a blast.
The 8T motor is playing havoc with the ball diff- my slipper must be too tight or I just haven't set the diff correctly. It's all kinds of gritty, with new ceramic balls.
- Jeep-Power
Upgrades!
The factory nylon front block was not able to retain the shock tower screws.
Went with the blue aluminum DHawk front block to support the 4mm front shock tower.
- Jeep-Power
Tore the diff down - the new ceramic balls and rings were trashed. Honed the rings smooth & flat and installed some new AE carbide balls I happened to have.
Now, I have been running these cars for over 30 years, but I am embarrassed to admit I never really knew how to properly set up a ball diff. Usually just tightened it down and sent it.
Just watched Spencer Rivkin's videos on ball diff and slipper setup - made a huge improvement and took the guesswork out of the process.
Diff build - I think he uses WAY too much clear grease, but he is a WC. Some good tips, none-the-less - https://youtu.be/lWXnyoxFwCc?si=GVR48U_8ZXZz7YVw
Diff break-in & tune; this is where the magic happens - https://youtu.be/eoFrvin7zrU?si=4_P6xLwXJ3HjtCth
Oh, and this is a great AE vid with TJ Eller on slipper clutch setup - https://youtu.be/g9xW2IN62So?si=ipVlZCqp1o5wxIs4
- 2058 Views
Last post by DaveM
- 1235 Views
Last post by aconsola
- 1037 Views
Last post by Dazza
- 1982 Views
Last post by Snake Plissken
- 19 Replies
- 3413 Views
Last post by RichieRich
- 19 Replies
- 2921 Views
Last post by Kaiser Q
- 4702 Views
Last post by sandbar782
- 1443 Views
Last post by Panhead383
Users browsing this forum: DotNetDotCom.org [Bot],
jcwrks,
Tbot [Bot] and 3 guests
