Lunchbox gear noise
Re: Lunchbox gear noise
Well after a bit I fixed her. What i did was teared the truck apart and cleaned the gears checked the bearings which were good and since I had it changed the gear box with a new one I had, checked my Yeah Racing oil filled dampers cleaned and tightened those and put her back together and bamo the prolem solved.
Forgot to mention I cleaned all metal bits (ie) rear axles, bevel gear pins even used autosol to polish them enery metal part in the gear box was washed and poished.
- Has thanked: 1153 times
- Been thanked: 624 times
Ya , The gears were pretty gummed up. I bought the truck used and just did a light going over. But what I did like I mentioned was a complete tear down and clean and rebuild. I mean I clean all gearbox pieces to new like condition and rebuilt the gear box with a new Tamiya gear box housing. What I did notice however was while I was disassembling the old gear box the axle on the right side was wobbling as I spun the axles with out the motor weird , I have come to the conclusion that the previous owner ran this truck hard cause after the rebuild axles spin free quiet and free. The gear box seems tighter as well , what I mean is there is less slop in the gears. I was going over other posts and found that a light coating of grease (used Tamiya ceramic grease from the kits) and used a Q-tip to cover the areas that needed it. What I also noticed no abnormal gear wear or pieces of metal. Ya so that's it sorry for the long post hope this helps some else.
- 3389 Views
Last post by losiXXXman
- 1327 Views
Last post by bird
- 577 Views
Last post by tamiya
- 1019 Views
Last post by tommy217xxx
- 1534 Views
Last post by badhoopty
- 912 Views
Last post by pmathews924
- 782 Views
Last post by vintage88
- 45 Replies
- 2420 Views
Last post by Dangeruss
