Yeah man! That would be great if you could find out the material for sure! At the least the community would have the answer for the future.
gold 8-32 aluminum screw alloy?
- Has thanked: 40 times
- Been thanked: 34 times
Re: gold 8-32 aluminum screw alloy?
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Whatever route you take, avoid the green screws from the re-re's. They are very weak, known for stripping and breaking the heads off.
- juicedcoupe
I will say this. I have lots of screw from various RC10's. Some seem to be better quality than others. Some seem cheap while others seem to be very good quality.
IMHO, its likely that they got whatever was available when they ordered them. Through all the years that they were used, it's likely that they used more than one supplier as well.
- Has thanked: 21 times
- Been thanked: 78 times
True, these were new old stock but who knows.. I didn't use them beforehand or even have a good history with these to recognize a good from bad by feel. All I know is these were original associated screws.juicedcoupe wrote: ↑Thu May 19, 2022 5:46 pm I will say this. I have lots of screw from various RC10's. Some seem to be better quality than others. Some seem cheap while others seem to be very good quality.
- Regular Member
Outside of corrosion or authenticity is there a reason to use aluminum? Am rebuilding my gold pan and sourced coated steel screws with the odd countersink. Is that going to cause an issue? It's not going to be a boat so the coating should be enough to keep from galvanic corrosion though I plan to watch out for it just in case.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
I imagine there is a negligible weight savings factor as well as the authenticity and "cool" factors. Many of the kit aluminum screws (different manufacturer) I used bitd were sheared off or came loose frequently. May have just been a 14 year old's aluminum screw experience though.AlexKitner wrote: ↑Fri Apr 12, 2024 7:48 pm Outside of corrosion or authenticity is there a reason to use aluminum? Am rebuilding my gold pan and sourced coated steel screws with the odd countersink. Is that going to cause an issue? It's not going to be a boat so the coating should be enough to keep from galvanic corrosion though I plan to watch out for it just in case.
- Has thanked: 1243 times
- Been thanked: 639 times
The Aluminum is a bit more forgiving to the nylon parts than steel would be. I do however really like the screws that came with the rc10ccAlexKitner wrote: ↑Fri Apr 12, 2024 7:48 pm Outside of corrosion or authenticity is there a reason to use aluminum? Am rebuilding my gold pan and sourced coated steel screws with the odd countersink. Is that going to cause an issue? It's not going to be a boat so the coating should be enough to keep from galvanic corrosion though I plan to watch out for it just in case.
ASC6316 rc10cc 8-32 screw set
Don't use screws with the wrong countersink. They won't sit flush and will snag as you drive. Galvanic corrosion is not an issue for rc10's
- Regular Member
Gotcha, my only concern was maybe the 7/8 ones might strip the threads where the pan and nose meet but I'm adding a bell crank with bearings and aluminum servo saver so those nylon nuts are at best making ebay if not the trash. I only needed to replace those 2 but found the right screws, 8/32 with the special head in black oxide coating locally in bulk decided id buy new 1/2's to replace the rest of the chassis screws in majority.
I have a bag of 50 and 15 or 25 of the 7/8 so maybe I'll make a kit with the leftovers and see if I can't cover what they cost me or if they'd be desired. I could get a custom kit bagged and ready, I have worked in truck and diesel aftermarket parts manufacturing and was able to dig up this place that's more manufacturing than retail by not walking in off the street.
- 1598 Views
Last post by KidAgain
- 935 Views
Last post by jamin
- 21 Replies
- 1985 Views
Last post by Lowgear
- 1211 Views
Last post by emerson_shih
- 1258 Views
Last post by Jedi Master
- 38 Replies
- 11264 Views
Last post by limestang
- 2468 Views
Last post by THUNDERSTRIKE1
- 2574 Views
Last post by JOHNBOY74
