The Siebenelch's on tour
- Minicooper 35
Re: The Siebenelch's on tour
Just a bit of tech stuff:
The stealth tranny held up well so far. The differential worked perfect, although I did not use new rings or balls. No re-adjustment was needed the whole evening.
Slipper-wise I noticed that it tended to open (and fade) a little bit. Maybe that's because of the 15 years old pads and the original slipper spring. I think I will replace both ASAP.
This is the setup I used:
Motor: LRP Vector X11 6.5T
Speedo: LRP Shpere Comp 2007 (Setup - AutoCell: 1, ADPC Profil: 3, Initial Brake: 2, Automatic Brake: 3)
Gearing: 16/87 (12,2:1)
Battery: Team Orion Carbon Edition 3200 LiPo
"The things you own, they end up owning you."
- siebenelch
- Been thanked: 4 times
I took a 5-cell EP4600-pack with a LRP-Speedo and a 8 turns Reedy Titanium-motor. The Punch and Speed was excellent with only 5 cells. I had no problems with the Slipper. I only had a broken roll-pin at a rear-wheel.
Here is the official Team MOOH Logo!
If I have time, I will continou the Vitec-thread. I am so busy the last weeks. Sorry!
Michael
Michael
- Attachments
- Team mooh2008.jpg (209.08 KiB) Viewed 915 times
Man I like those cars.... What are those front wheels and tires? are these 2.2?
- Has thanked: 7 times
- Been thanked: 42 times
Front and rears appear to be 2.2" with the rear being B3 rims and probably the front's too.
- Minicooper 35
Rear wheels on both B2/B3 with Schumacher 4WD Mini-Pin tyres.
Front wheels on Michael's car 2,2' for "flange less" bearing (don't have the partnumber handy but I think in the 948x range for #3977 bearings) with Schumacher Stagger Rib tyres.
Front wheels on mine are "wide body" (no partnumber handy too) with Schumacher 2WD Mini-Pin tyres.
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
9482 are the wide body B3 front wheels, 9481 are the narrow. 9480 are the uber rare B2 only fronts...Minicooper 35 wrote:Rear wheels on both B2/B3 with Schumacher 4WD Mini-Pin tyres.
Sadly, all are discontinued...
- Minicooper 35
Temple, where's the difference between these two? Michael and I found that we have two different "narrow" front rims. One had a "taller" "bead" (the circles part) one was a bit narrower in height.templeofspeed wrote:9481 are the narrow. 9480 are the uber rare B2 only fronts...
- templeofspeed
The taller bead (also with eight ribs rather than six) that uses non-flanged bearings are the 9480 B2 wheels.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Fantastic cars! Thankfully, no one posted any pictures of Michael or Sebastian in ass-less chaps.
- Has thanked: 183 times
- Been thanked: 157 times
damn dude... how do you know all this stuff???templeofspeed wrote:The taller bead (also with eight ribs rather than six) that uses non-flanged bearings are the 9480 B2 wheels.
we so much need a tech area...
- templeofspeed
Once a parts guy, always a parts guy...badhoopty wrote: damn dude... how do you know all this stuff???
i didnt mean it was a bad thing.templeofspeed wrote:Once a parts guy, always a parts guy...badhoopty wrote: damn dude... how do you know all this stuff???
i was more like daaaammmn dude... you know.
- Minicooper 35
Temple is good and defo need his own "ID-my-part" section!badhoopty wrote:damn dude... how do you know all this stuff???
- Minicooper 35
After a bit of research at the German empolyment agency Michael was able to find us a proper mechanic. She will also care for the catering at the race meetings ...
Mooooo ...
Mooooo ...
- Attachments
- b07.jpg (27.12 KiB) Viewed 712 times
- Tadracket
Got Milk?
He's an idiot. Comes from upbringing. His parents are probably idiots too.
- 850 Views
Last post by limestang
- 387 Views
Last post by Dangeruss
- 1294 Views
Last post by adam lancia
- 47 Replies
- 7644 Views
Last post by mikedealer
- 1657 Views
Last post by badhoopty
- 24 Replies
- 2342 Views
Last post by RichieRich
- 1369 Views
Last post by XLR8
Users browsing this forum: DotNetDotCom.org [Bot] and 4 guests
