RC10 Composite Craft Worlds build
Re: RC10 Composite Craft Worlds build
they are black anodized.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
Oh right you said that originally :oops: 8)
Hey Cru ! Go balls out 8)
Lavigna
Has thanked: 1099 times
Been thanked: 1418 times
Post by Lavigna »
I haven't progressed on this build because I realized my lower chassis is the SHORTER version, and doesn't fit my upper deck. It doesn't have the servo saver cutout either, which I believe is the easiest way to identify between the 2 different length chassis'. The upper deck I have if for the longer version.
I am now torn between waiting and hoping to find a longer lower chassis, or simply modifying the front of the upper deck to fit. Cutting the upper deck to fit would be simple enough, but it would mean it will never fit the longer chassis again. I would prefer to have the longer chassis.
Anyone want to trade?
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
Ask the tractor guy you bought it from if he has the matching part. He's been known to swindle people.
The TX SKUNK
The pictures you have on the first page all look right. The cutout for the servo saver is for the truck. I don't think there was a middle length chassis, just truck and buggy. Where are the problems with the upper plate you are seeing?
MarkyDents
Mine does have a servo saver hole…. Didn’t realize that till you said it. What about getting the correct length top deck from Jeff ? I see now that your top deck would pass the front of the lower chassis when mounted to the rear bulkhead. Seems like there were two different length buggy chassis’ then. Because my wheelbase is the same as the team graphite.
How much shorter is it?
yeah, like i said, I don't think they made more than 2 rc10/t chassis. do the 4 extra support holes line up with the chassis?
Lavigna
Post by Lavigna »
Jwscab - That's not correct. There are 2 different lengths of theCC RC10 chassis and top plate. They have nothing to do with the CC RC10T chassis. I just happened to get a long top and short bottom chassis.
Jcwrks - Chad is a great seller. He immediately offered me a full refund when I noticed the issue.
MarkyDents - Exactly
Scr8p - The top plate is about 1/2" longer in the front. All the other mounts line up perfectly.
mikea96
Has thanked: 659 times
Been thanked: 878 times
Post by mikea96 »
It looks like you could easily trim that front back to make it work that is if the back half is in the correct spot.
Lavigna
Post by Lavigna »
mikea96 wrote: Tue Oct 26, 2021 8:55 pm It looks like you could easily trim that back to make it work that is if the back is in the correct spot.
Yes, it's a simple job,and it would look the same. I'm just not sure if I want to use the shorter chassis, or wait and hopefully find a long one. Once I cut the top plate I can't go back.
So the chassis is a 1/2" shorter?
I'm gonna assume that if you shortened that brace to make it work, you'd probably have to out the " T "for servo arm clearance. Make it like the truck top plate.
Wow that's crazy. That's something I've never seen before, nor even heard of.
I have a broken short top deck if it would help as a template. Actually, I don't really know then what length the chassis is. Give me a dimension on the overall length or something to compare.
this one measures 10.7" from end to end.
Lavigna
Post by Lavigna »
Jwscab - My top plate is the same as yours. Same length. However there is another version that is shorter in the front to fit my bottom chassis.
The picture below (isn't mine, its from a recent ebay listing) shows the short lower chassis (like I have) and a short upper deck (unlike mine). Notice the angle of the front triangles is different due to the shorter length.
