Very young youngtimer ;) Hot Bodies D413
Forum rules
Trass
Has thanked: 487 times
Been thanked: 258 times
Re: Very young youngtimer ;) Hot Bodies D413
Post by Trass »
more and more ;)
Jerome
Trass
Post by Trass »
Week-end work, motor installation, but polishing first ;)
Tomorrow i will start rebuild of a wing from scrap, as i do for my CAT SX ;)
Jérome
Trass
Post by Trass »
Hi every body,
I worked on an old wing as i do for my Schumacher CAT SX;
there something wrong with it, i will looking in an other way tomorrow.
Jerome
Trass
Post by Trass »
New kork on the wing;
cit's better ;)
quick paint;
Jerome
Trass
Post by Trass »
Not really some great news, but i received a brand new damper spring protector. it fit better ;)
Jerome
Trass
Post by Trass »
More build on that chassis.
Pics taken on may 2020 (i forgotten to post them... sorry)
Removing of anodising and polishing from today ;)
Before :
After :
Now, i need receiver plastic holder and rear alloy hub...
Jerome
Trass
Post by Trass »
Trass
Post by Trass »
need M2.5 screws to continue...
Jérome
Trass
Post by Trass »
Hello!
Here we go again ... ;)
Receiver plate arrived, little working on it.
To be continued ...
Jérome
Trass
Post by Trass »
Hi,
Next step : poliched servo saver :)
To be continued ...
Jerome
Trass
Post by Trass »
i started to cut the 4 parts of the body. The factory body parts are not well adjusted even the drilling point....
Body parts are assembled with Inox A2 screws ;)
Jérome
matt1ptkn
Has thanked: 80 times
Been thanked: 133 times
Post by matt1ptkn »
You really do amazing work! 8) Why did you put the O-ring under the receiver plate? Is it just to keep the plate off the chassis to prevent scuffs?
Matt
I'd have that receiver plate mounted with at least 2 attachment points. With just one, with an offroad buggy, it's guaranteed to start swivelling once that single mounting screw loosens up a bit. Maybe a little square of servo tape underneath would also prevent this. The wing setup doesn't look optimal to me. Maybe it's the perspective of the camera, but it seems to be hanging too low at the trailing edge which won't be ideal for airflow or downforce. The addition of the side plates only seems to give the illusion that the wing is horizontal.
I'm digging all the rest of your work though, loving the polishing and fabrication skills! 8)
Trass
Post by Trass »
matt1ptkn wrote: Fri Oct 15, 2021 7:24 am You really do amazing work! 8) Why did you put the O-ring under the receiver plate? Is it just to keep the plate off the chassis to prevent scuffs?
Many thanx!
Exactly, even this chassis will never run or just for exhibit and i love the looking of this space between receiver plate and chassis ;)
Coelacanth wrote: Fri Oct 15, 2021 10:52 am I'd have that receiver plate mounted with at least 2 attachment points. With just one, with an offroad buggy, it's guaranteed to start swivelling once that single mounting screw loosens up a bit. Maybe a little square of servo tape underneath would also prevent this. The wing setup doesn't look optimal to me. Maybe it's the perspective of the camera, but it seems to be hanging too low at the trailing edge which won't be ideal for airflow or downforce. The addition of the side plates only seems to give the illusion that the wing is horizontal.
Many thank you!
This chassis will never run or just a bit. You are right about the servo tape if it have to race ;) The wing position is just to have a kind of good looking.
I will ask to Manobet to design a nice aluminium wing mount, and in this position, i will can show that Manobet's piece of art ;)
Jerome
Trass
Post by Trass »
First tests for the Body.
To be continued...
Jérome
Users browsing this forum: No User AvatarGoogle Feedfetcher and 1 guest
