Driven it some more and it's definitely tail happy ! You can get the back end out on loose surface and spin up the back tires ! You could probably tighten the centre diff up to give more drive to the front and if it was easy to get parts I'd give it a try but although it's designed to be adjustable it's still a geared diff and won't live long that way , it's still fun to drive .
I guess the meat and potatoes question is how does it compare to the Hotshot ? Sadly the Hotshot with a lower centre of gravity and mid motor design means it's hands down better handling , the Samurais saving grace is it's steering though , it's got no bump steer and turns way better without dropping dog bones all over the track because of the 3rd diff .
I guess only time will tell if the under guard saves damage but even for a little driving there are rub marks under the rear gearbox .
Armour For A Samurai
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: Armour For A Samurai
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
- TheDiamondOne
- Has thanked: 1571 times
- Been thanked: 405 times
She's pretty quick considering. Handles like a dream to boot!
The video is with the stock silver can motor and a Tekin gold Fet on NiMH 7.2v , it's quite light too 1.6 kilo fully loaded compared to my Hotshot racer of 1.55 kilo !TheDiamondOne wrote: ↑Sun Mar 28, 2021 11:02 pm She's pretty quick considering. Handles like a dream to boot!
Just swapped the motor for a bit of a mystery motor I got recently , it's a helicopter motor with a nice red alloy front can end a bit like a Kyosho Le Mans can, it's a triple wind probably about 18 turn , goes pretty well with it in my front garden this car is really nice to drive , I'm homing in on a good shock set up , it came with really to thick oil in the rear so I went to 10wt , that was too low but 20wt seems good , it's so heavy at the back the springs are set quite hard to stop it bottoming out , I'm not surprised that the rear upper shock mounts are a regular weak point in the design , the front end is beautiful to watch , the wheels just flutter over the bumps , a total contrast to the rear , it's tempting to try a much lighter battery to even out the balance a bit .
- 2040 Views
Last post by rhyde
- 19 Replies
- 3737 Views
Last post by naushad
- 1162 Views
Last post by dahlelama
- 19 Replies
- 2615 Views
Last post by Mr. ED
- 43 Replies
- 5152 Views
Last post by DennisM
- 1896 Views
Last post by cyberfox
- 31 Replies
- 4397 Views
Last post by Dadio
- 19 Replies
- 6108 Views
Last post by optimaforever
