Original stealth slipper: 6594 + 6587 modern replacement?
- juicedcoupe
- Has thanked: 260 times
- Been thanked: 1975 times
Re: Original stealth slipper: 6594 + 6587 modern replacement?
Looking up the 6582 on AE's site, it lists the B2 and B3 in the applications.
- Has thanked: 1197 times
- Been thanked: 582 times
Isn't that part used on literally every associated ball diff?juicedcoupe wrote: ↑Thu Jan 13, 2022 1:54 pm Looking up the 6582 on AE's site, it lists the B2 and B3 in the applications.
I know it fits, even though a little small, is it the right strength?
- Been thanked: 496 times
They are really similar so it has to be close. Maybe too much though? A stiffer spring will narrow the slip range somewhat. Couldn't hurt to try.
It may be to much thought. I am not looking for an exact match but something ball park enough to have similar performance. If the stealth slipper spring is close enough I'll pick it up and be done with that.
I was actually the diff spring would be softer than the slipper spring given it is supposed to supply it's force over the smaller area. I can verify that the schumacher spring 4673 is .07" wider than the stock spring .38 OD vs .31 od with a similar length to the stock. it would need some kind of adapter washer to use the standard hub and 5-40 nut.
- Frankentruck
- Has thanked: 2421 times
- Been thanked: 2730 times
For a stiffer spring, the nut is tightened less. For a softer spring, the nut is tightened more. How much force the spring applies is related to how stiff it is AND how much it's compressed.
- duckhead
- Has thanked: 160 times
- Been thanked: 190 times
Not sure if Dynotech is still in business or not, but they have this listed on their site:
https://dynotech-racing.com/partDetail.php?RefNum=9018
Based on the description and how it looks in the picture, this could be an option.
- Been thanked: 19 times
HPI used what appeared to be a stealth slipper on the RS4 MT truck. You can still get the thrust washer set on ebay. HPI A223 is the part number.
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
The 6582 is what goes inside of the diff and that is still made. It's a bit smaller than the official slipper spring, but if it works and is still made it's good enough.duckhead wrote: ↑Thu Jan 13, 2022 9:52 pm Not sure if Dynotech is still in business or not, but they have this listed on their site:
- 1589 Views
Last post by littleVETTE
- 802 Views
Last post by AustinZ
- 1074 Views
Last post by Kaiser Q
- 2143 Views
Last post by sbednara
- 3124 Views
Last post by CBR240
- 1594 Views
Last post by mdutcher
- 565 Views
Last post by paul
- 1649 Views
Last post by Caine
