Thanks Jeff! I'll check with Barbara about getting some.
Factory Works 180* Steering Bellcrank Build
- NomadRacer
- Has thanked: 81 times
- Been thanked: 79 times
Re: Factory Works 180* Steering Bellcrank Build
Bum on Direct Deposit
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Front axles are relatively easy to make on the lathe Nomad. The only tricky part is drilling the hole for the hinge pin as it has to be located perfectly or the pin could bind when everything is assembled. It's probably best to make a drilling fixture to prevent the bit from wandering off center.
I'd bet you could make a set of axles that would be absolutely stunning!
Yeah a v block and center or spotting drill in a drill press works well. I just made some associated pairs for Joey King, as well as losi/trx pairs.
- NomadRacer
I think I can make them, drilling and threading the end either 5-40 or 4-40 (which ever you like) with no problem. I do have a chunk of 1/4" and 5/16" Titanium rod (prefer over alum.) in my stash.XLR8 wrote: ↑Tue Nov 20, 2018 11:19 am Front axles are relatively easy to make on the lathe Nomad. The only tricky part is drilling the hole for the hinge pin as it has to be located perfectly or the pin could bind when everything is assembled. It's probably best to make a drilling fixture to prevent the bit from wandering off center.
- XLR8
Hmmm, those are some great suggestions Joe.
Makes me wanna fire-up the lathe and try them out.
I don't have a v-block but I could improvise/fab something equivalent.
I've just used a vise before and clamped it to the press table. All the magic is setting up the centerline. Well, the second piece of magic is the stubby drill to prevent wander.
- NomadRacer
Yep, stubby, or sometimes called machine screw length drill bits are a must, they're all I have. Go for solid carbide bits for rigidity.
If you use a center drill it's even better. I think a #2 is the right one. A spotting drill is the 'correct' tool though.
If you don't have any, you should use them with your lathe, for center drill or making a 60 degree pilot for a live center
- XLR8
I don't know what these are called but this is what my Dad had in his shop.
He was an amazing guy; without any formal machinist training, he could make anything on a lathe and a bridgeport.
Those are center drills, and you appear to be holding a #1. They are generally used when making a 60 degree pilot in the end of stock so it can be supported in a tail stick with a center.
- NomadRacer
Yes, center drills and a nice vintage looking set. They'd look good in any tool chest.
Sometimes you have to use the tools you have to do a job, like using a center drill to do a chamfered hole. Is it the right tool? no. But it'll get the job done.
- NomadRacer
Small update for today, working on the trailing arm pivot post...
The first thing I do is remove any flashing from the posts. This is so they fit in my ER16, 1/4" lathe collet nice and true. I use diamond coated files to get the job done.
Now, I head to the machine shop for some "groovy action". First, I turn the post to make it true. This is done with light cuts, 0.001-0.002" at a time. Next the grooves. I come in 0.050" from the end and cut four grooves, 0.030" spacing, 0.060" deep. They look pretty good to me. Finally, I use a 1/8" hand chucking reamer to remove any internal burs in the hole. I'll continue working on the posts till they are all nice and shinny, well, not a true shine, a sort of fine brushed finish is what I'm after.
- Has thanked: 14 times
- Been thanked: 60 times
- NomadRacer
- 1469 Views
Last post by ZED32
- 94 Replies
- 12100 Views
Last post by NomadRacer
- 22 Replies
- 4326 Views
Last post by XLR8
- 5204 Views
- 1489 Views
- 5004 Views
- 736 Views
Last post by highwayracer
- 907 Views
Users browsing this forum: DotNetDotCom.org [Bot],
Tbot [Bot] and 3 guests
