I need help to get a little more speed on my RC10T4.3
Forum rules
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: I need help to get a little more speed on my RC10T4.3
I think I ran 26/87 with a 3450kv 10.5T
- Regular Member
Quick update guys: I re-calibrated the ESC and speed went up from 20 to 25 mph which is great news ! so thank you for the advice !
A different question now: If I want to bump top speed from 25 mph to 30 mph, re-gearing sounds like an option. Current pinion is 18T but the motor manual says 19T is a safe average. Should I try a 19T pinion to test speed and temperature or should I jump to one even higher like 20 or 23 ?
Note: the motor is still only warm by running at 25 mph for quite a while, looks like there is room for temperature there and re-gearing.
Thanks guys !
Thanks guys !
try a 22 or 23 tooth pinion. It won't hurt doing testing with a larger pinion. Worst case is you run it around and if it lugs and gets hot, you know you are overgeared. Otherwise, it will probably be fine.
- Been thanked: 325 times
Great to hear you're back on track with the ESC recalibration. Keep in mind that, all else being equal, the higher you gear up for top speed, the slower your acceleration will be. You can compensate for this somewhat by adjusting your ESC "Punch" setting.
- 1736 Views
Last post by Dave145
- 1069 Views
Last post by Panhead383
- 1048 Views
Last post by j.d.roost
- 34 Replies
- 4708 Views
Last post by nitrous36
- 2197 Views
Last post by juicedcoupe
- 2520 Views
Last post by RC104ever
- 651 Views
Last post by Dangeruss
- 1633 Views
Last post by MelvinsArmy
