Bringing up this topic again, as I have questions. To start, its seems the more I learn, the less I know.
Anyway, I recently acquired a large lot of RC crystals from my (now closed
) LHS. As I am going through them all and trying to match up pairs and organize everything in numerical order, I've found that there are more frequencies than I thought for RC. I'm only familiar with 27 and 75 MHz AM and was aware of 72 MHz for air use. I have no experience with other frequencies, FM or PCM. After 75 MHz AM, I went straight to 2.4 GHz. I've also got some odd ball frequencies that I can't find anywhere, mainly in the 30-40 MHz range. I'll get some photos to back up my questions.
1. AM / FM: I understand (enough) about the difference, but what (if any) is the compatibility? I've read that 27/72/75 MHz transmitters work on both AM and FM, but that receivers are only one or the other. True or False? Will there be any connection between AM and FM crystals that are the same frequencies?
2. Different Brands: Some crystals state that they are for specific brand(s). Will these work at all in other brands? Is the branding specific to the transmitter, the receiver or both?
3. Conversions: I have no clue what the single conversion versus dual conversion is. Does each type only work in specific transmitter/receivers? Is there any compatibility between single and dual conversion crystals?
4. Single Crystals: I have a handful of NIP single crystals. I thought you always needed a matched pair, ie: same frequency, same band, same type, same brand. Will these single crystals work with any others on that frequency, or are they specific to only that brand, etc.?
5. Identification: Is there a way to ID a blank crystal? Or if it is only labeled with the frequency, is there any way (other than trial and error) to determine what it (should) work with?
If you've read this far, thank you for your time. If you have answers, please
- why-dont-you-explain-this-to-me-like-im-five.jpg (38.69 KiB) Viewed 1394 times
. THANK YOU!!!
