Trannies on the corner...
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Trannies on the corner...
That looks great. There is still demand for those if you ever decide to try to do some work
- NomadRacer
- Has thanked: 81 times
- Been thanked: 79 times
Well... I don't really like "work"
What I could do is make a few as trading material. I've got to get a diff shaft to see how things fit and if I need to bore out the back side of the cover to clear the end of the shaft and e-clip. On the prototype, the cap inserts to a depth of 0.060" in the bearing adapter.
Bum on Direct Deposit
- NomadRacer
NomadRacer wrote: ↑Tue Oct 24, 2017 5:06 pmWell... I don't really like "work"![]()
What I could do is make a few as trading material. I've got to get a diff shaft to see how things fit and if I need to bore out the back side of the cap to clear the end of the shaft and e-clip. On the prototype, the cap inserts to a depth of 0.060" in the bearing adapter.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Please do the same for a stealth
- NomadRacer
I have a couple of Stealth caps on the bench right now, 2 aluminum and 1 titanium. I'm out of 3/8" dia. aluminum so it will be a while till I get some more made. I can make a couple more titanium, then I'm out of that too.
- NomadRacer
- Lonestar
That's lovely... not sure I have anything to trade really, but if you feel like selling one, well, I'd happily sport it on one of my cars!
- NomadRacer
- NomadRacer
I need a bit of help from the Guru's on the 6-gear tranny...
The manual says to tap the tap the diff pinion onto the diff tube. What I'm not getting is how far, how much?
Just to seat it. That should be fine. You don’t need to use a press or anything. It’s somewhat like setting a Jacobs chuck in a drill press
Right, it's a taper fit, just be sure it's seated squarely and that's it. No further pressure. Once it's assembled with the top shaft and thust and diff gear the spring and nut apply pressure to keep seated and locked.
- NomadRacer
Thank you kindly, gentleman!
I'm doing some work on the trannies
today, prepping the diff rings and such.
- NomadRacer
I received the final parts for the Stealth tranny this morning. I went with the vented slipper plates because they look cool
The tranny spins smooth as heck on compressed air.
Do I leave it natural, dye it black or maybe red
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Looks fantastic! I tend to prefer natural but I guess the color depends on what you planning to install it into. So this leads me to my next question; what are you going to install into?
- NomadRacer
- 33 Replies
- 3685 Views
Last post by Brat
- 1725 Views
Last post by cheropache73
- 1918 Views
Last post by Qballll
- 2757 Views
Last post by AllenB.5979
- 1257 Views
Last post by surgetek
- 1108 Views
Last post by vonBraun
Users browsing this forum: Bing [Bot],
howsyouraspen and 4 guests
