Very nice!
Thanks. Yeah, I was hoping the polish would make them pop against the black.
Thanks. I spent a lot of time on it to make it as perfect as I could.
Great. Thanks for the links. I used your part numbers, and it turned out great. I got a set of black springs. I think they look nice. I may also change out the shock shafts to some FT unobtanium units, for their darker color. They should fit into the whole stealth look.DaveM wrote: ↑Sun Jul 23, 2017 8:06 pm Hi,
I am loving it!
Keep the ball studs stainless.
Front shock springs, Black, Asc 7426.
https://www.amainhobbies.com/team-associated-front-truck-shock-spring-2.765lb-black-2-asc7426/p2421?r=0
Rear shock springs, Black, Asc 6481.
https://www.amainhobbies.com/team-associated-rear-buggy-truck-shock-spring-1.74lb-black-2-asc6481/p2419?r=0
Black spur gear?
https://www.teamassociated.com/parts/search/?t=parts&query=8285
Good eye. I actually picked up a set for spares.scr8p wrote: ↑Wed Jul 26, 2017 9:09 am Looks good!
Don't forget the RPM servo mounts.![]()
https://www.amainhobbies.com/rpm-servo-mounting-posts-rpm70062/p47769?gclid=Cj0KCQjw--DLBRCNARIsAFIwR27g0u5IwMgXGXqZPLprUBy9vMIINlkBwhtVX5oZhxIdqyBDqIDYW4QaAniWEALw_wcB
Great timing. I was just searching for some servo mounts for this build. I hadn't considered these, but they will be perfect. Thanks!scr8p wrote: ↑Wed Jul 26, 2017 9:09 am Looks good!
