Tools!
- lmw94002
- Been thanked: 9 times
Re: Tools!
I got the new AE multi driver pictured and it's great. I still use the old AE invidual anodized allen drivers on the bench.
4.5" channel locks are definitely useful in many situations. Add the long/fine needle nose... that'll get you through most scenarios.
--Builds--
--Builds--
- duckhead
- Has thanked: 162 times
- Been thanked: 205 times
Re: Tools!
I am curious what folks use to remove snap rings, especially the small ones. I've tried to find snap ring pliers with bits that small, but I don't think they exist.
Also, has anyone come across a driver or bit that fits the tiny screws that secure the bearing in the idler gear inside 6-gear transmissions?
Re: Tools!
what kinda snap rings? for e-clips and the snap rings in shocks and outdrives in the 6 gear I use my 00 tweezers and a dental pick to lift and walk out of the groove.
- lmw94002
Re: Tools!
I have a fine tip jewelers flat head for removal of clips/rings. The tip is very small, and just a little twist will start to remove it and then use it to pull it off the shaft.
Also for eclips I have a very fine point set of needle nose pliers that work well as a long as the eclip isn't really flush against the surface of the part.
--Builds--
--Builds--
- 1911 Views
Last post by adam lancia
- 416 Views
Last post by OldSchoolGuy
- 1587 Views
Last post by NomadRacer
- 285 Views
Last post by Lowgear
- 839 Views
Last post by jdenison75
- 1759 Views
Last post by kink
- 37 Replies
- 10232 Views
Last post by Frankentruck
- 52 Replies
- 12679 Views
Last post by Willrcboy
Users browsing this forum: 80sRunner,
Semrush [Bot] and 4 guests
