TRX-1 Mods and Parts guide
Delorean
Has thanked: 17 times
Been thanked: 14 times
Re: TRX-1 Mods and Parts guide
Post by Delorean »
Thanks to Klavy69 for adding part numbers to the original post etc, just added badnats slider driveshaft replacement using integy bandit hardware
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
your welcome. Anytime I can try to help out I will to keep some love goin on these forgotten traxxas's :wink:
I just read the part number in the other thread and was thinkin of this thread so worked out pretty good.
thanx for the thread 8)
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Have I mentionned that the AE battery boxes are a direct fit on the chassis with the right hole spacing?
However, beware: the AE battery bar doesn't fit on the TRX box mounts :(
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Post by TRX-1-3 »
This is an interesting thread as far as mods/parts
http://www.rc10talk.com/viewtopic.php?f=31&t=30798
Especially:
"RB5 rear CVD's with Kyosho outdrives."
I wonder if these would solve the A&L trailing arm clearances issue? (Around the ID of the inboard bearing bore area of the trailing arm) I guess traxxas universals are too bulky.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
http://www.rc10talk.com/viewtopic.php?f=31&t=18468
You may want to have a look at my tcp too
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
This is great....I have my TRX1 that has been begging me to rebuild it. Getting a few A&L goodies then will be digging in! My goal is to get it ready to race and be able to use 12mm hex wheels on all 4 corners. If I cant get the front done easily, then at lease adapt it for my RC10 WC front wheels, I just despise having to carry around all different set of front wheels/tires when I go racing - trying to keep it to 2 kinds, hex or bearing only.
Patrase
Post by Patrase »
I have found that the Axial 20t top gear fits the TRX gearbox perfectly. It's made of metal - so much better than the plastic parts and its cheap . Part AX30394
Also, the 18mm HSP idler shaft works perfectly. I use the Traxxas 1996 idler and insert narrowed Tamiya plastic bushings in the transmission housings and run bearings inside the 1996 idler.
Plus with the Haiboxing/HBX slipper Shaft looks like it fits, part HBX-KB-61035 using Kyosho or Schumacher (with internal bearing) spur gears. This might be useful for non AE or Losi guys. Also usefull as the STRC topshaft doesnt seem available at the moment, although i have seen a few top shafts that can use older losi dual pad slipper plates (XX or XXX or early 22 compatible), which allow Losi or AE dual pad spur gears.
Supernaut
Has thanked: 5 times
Been thanked: 68 times
Post by Supernaut »
I will just add this here for what I did.
Love to build......need to practice painting
Associated - Worlds, B6D
Traxxas - Rad2, TCP, Stampede, Villain IV
Tamiya - CLODBUSTER
As you can see....I sold most of my cars. Funding Pinball now.
Mr. ED
Post by Mr. ED »
why the a&l axles? They look quite a bit longer: don’t they bind up in the diff outdrives?
Supernaut
Post by Supernaut »
Yes they are too long. I need to machine them down.
Tamiya - CLODBUSTER
Been thanked: 3919 times
Those appear to be our bones for the lethal weapon conversion not the standard bone conversion. Pretty bad example as it makes it look like our parts are wrong when they have been used for years and inspired the Traxxas parts :roll:
Supernaut
Post by Supernaut »
When I ordered I thought all you had was the lethal weapon bones left? If you have Trx1 bones I can just order those.
“The bones for a standard TRX-1 are gone, but we do have some left for the lethal weapon conversions (slightly longer). ”. This was at the end of January.
At least at the time that is what I was told.
Tamiya - CLODBUSTER
Correct, the TRX1 bones are gone.
However you are representing the lethal weapon bones as the ones we sold for trx1 though, and that is very misleading. It would be like complaining that you had to buy a 4 door car because there were no 2 door models left on the car lot and for some reason the car has a longer wheelbase. Yeah, the bones are too long because they are for a different application, not because they were made wrong or sold as the right ones
Supernaut
Post by Supernaut »
Sorry I was not clear. I will edit my picture.
I have never seen A&L trx1 bones, not even ran across them on eBay. Regardless my only option is to machine the bones down from the LW and this looks like it would be most people’s best option for a build unless someone chimes in on some other option. And this is exactly what I am doing getting what is available and making it work for me and I am not complaining about it.
Picture updated
Tamiya - CLODBUSTER
Retro rc
Has thanked: 665 times
Been thanked: 473 times
Post by Retro rc »
Legacy model lists are still up on. The traxxas website
https://traxxas.com/support/PDF-Downloads-Legacy-Models
Return to “Traxxas Forum”
