Servo Survey
lmw94002
Been thanked: 9 times
Re: Servo Survey
Post by lmw94002 »
For my "old" cars I picked up some Hitec metal gear servos for playing around and I know they work good w/ my old radio gear. While I was at it, I bought kimbrough servo savers for them as well. Since I'm not sure if they'll end up in a RC10, a DS, or a 10LSS...
For the new B6/B6D that I hope to race (once I put one together)... I went with Savox based on the local recommendations I got to use w/ the new radio gear.
--Builds--
sandbar782
Re: Servo Survey
Post by sandbar782 »
yellowdatsun wrote:
Actually, if you use the stock steering stuff, I believe that white oval piece is the servo saver.[/quote]
I was unaware of this can anyone confirm this?
Re: Servo Survey
yes, the non-worlds steering bellcranks have a servo saver built in. historically, the hot tip of the day was to add some tie wraps to snug up the saver portion.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDSWE&P=FR&gclid=Cj0KEQiA4JnCBRDQ5be3nKCPhpwBEiQAjwN1bkyJdLV6OJB5YsSNCzDtaQ9u7wk-grrhmr3chSMwCk4aAhxQ8P8HAQ
dsmith
Re: Servo Survey
Post by dsmith »
was using futaba's...but not no more.....now......savox...they have good ones for around $25......
sandbar782
Re: Servo Survey
Specifically does the worlds rere have a servo saver built in. I guess that was really my question.
lmw94002
Re: Servo Survey
Post by lmw94002 »
I'm pretty sure it uses the same bellcrank as the original worlds. I always ran a kimbrough servo saver on the stock and after market bellcrank steering systems when racing after I destroyed my first servo without it.
--Builds--
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: Servo Survey
Post by JK Racing »
sandbar782 wrote:Specifically does the worlds rere have a servo saver built in. I guess that was really my question.
Worlds - no
Classic - yes
sandbar782
Re: Servo Survey
Worlds - no
Classic - yes
Got it. Thank you.
rccars4sal
Re: Servo Survey
Post by rccars4sal »
Ive never had good luck with hitech car servos. I use the micro aircraft servos alot, and very reliable units. I have killed 2x 605bbmg servos in a slash, and several 425 servos just failed or were incompatible with my crappy radio gear.
Stuntmanmike1975
Re: Servo Survey
Post by Stuntmanmike1975 »
Im a bit late to the party but if I may?
Ace 1313 Digital- The last servo you'll ever have to buy for about $100
I use these in all my better cars/ aluminum case and metal gears very strong and versatile.
Also
any of the JR's or Savox
or the cheap & reliable
Hitec HS645MG- surprisingly strong & reliable for about $35
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Servo Survey
Post by Lonestar »
Stuntmanmike1975 wrote: Mon Mar 20, 2017 12:58 pm Im a bit late to the party but if I may?
He doesn't want a $100 servo for a $100 car ;)
kiohio
Re: Servo Survey
Post by kiohio »
I have bought and beat on the following, Savox 1258TG, Savox 1251 and Power HD 1207TG.
All of them have done very well with no issues whatsoever.
I use full size on the RC10T's and the compact ones on my RC10's
KO
Timmahhh
Has thanked: 9 times
Re: Servo Survey
Post by Timmahhh »
If you're just looking for something to play around with, keep an eye out for deals from reputable sellers on metal gear servos (new or used). You dont really need a servo saver on metal gear servos, and not running one will get you a little better steering response. I run a rebranded savox (orion) in my race car, and its good, but savox servos can draw a lot of amperage. Futaba, Airtronics/Sanwa, and KO Propo are all awesome, but pricey. Savox and Hitec are what I'd consider the next tier... a little cheaper, and still good, but not AS good (Savox with power consumption, some hitecs dont center great)... and then you have the budget servo brands like hobbyking, power HD, etc., which are probably fine for a lot of applications, but sometimes overrated on specs. In a buggy, I'd look for at least 90 oz of torque, and 150oz for a truck. .10 or better will be really fast, any once you get over about .15 for speed, you'll start to notice it being a little slow.
Ucsdmutt
Re: Servo Survey
Post by Ucsdmutt »
I like the Savox 1258TG.
I have the plain yellow one, a Black edition, just ordered a Ryan Cavaleri version.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: Servo Survey
Post by RC10th »
Power HD1207TG is a good servo for the money. Not particularly torquey but good speed and I've never kiiled one.
+1 for JR servos though....
