Took the tranny apart and installed into a 1991 stealth case. Still some play in the top shaft. Has to be sub standard bearings... I can live with it so I put it back in the 10T case I purchased aftermarket for the Re-Re. Top shaft runout was fine too..
Spur wobbles like a b!t@h still. Thing is just garbage. Going to try a Kimbrough aftermarket gear and see what happens....after we burn up the stock one.
I love the car but there are some quality issues I've noticed throughout the build, this being the main one.
Thanks for everyone's input.
worlds spur gear wobble problem ?
Re: worlds spur gear wobble problem ?
didn't someone replace the entire slipper unit on one of these.
I took a short video of my original RC10 graphite w installed after stealth transmission from that era, 1990??? It has a Robinson Racing 84T spur installed. Thing rolls smooth as a Swiss watch. It's silly.
I'd post the video if I knew how.
- Been thanked: 7 times
Was rebuilding the trans in my B2 yesterday and remembered reading this thread. I too had a slight wobble in my spur gear (updated top with the B4). I never had an issue running it with the wobble, but it was bothering me. After checking everything a million times, I noticed the spring was not square. This was causing uneven pressure on the slipper assembly and the wobble. I replaced the spring with a new one, that is square, and the wobble went away. You can see in the picture how the spring leans to the right, ever so slightly.
- 2373 Views
Last post by limestang
- 2122 Views
Last post by minimini
- 1356 Views
Last post by jackflak
- 802 Views
Last post by shredderboy
- 2556 Views
Last post by JK Racing
- 1119 Views
Last post by Chemical
- 736 Views
Last post by Qballll
- 772 Views
