Rere Plastic shocks!!!
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Rere Plastic shocks!!!
Post by Lonestar »
Avid does similar ones.
Then there's the BK method (which is about grinding the top or bottom side that rubs) but it has never worked for me.
harvey
Post by harvey »
I vote for big bore springs as well. The traxxas (3768) spring cups are adequate, but I haven't tried Niki's. You can try winding some small dia shrink tube down the coil and fiddle it into position at the top to torque the spring off the body. I've had some success with this method, but my runners got big bore's.
bully
Been thanked: 6 times
Post by bully »
Like harvey said you can wedge the spring with something to offset the rub. I used to use 3mm strips of that chassis protective adhesive wedged between the spring top and the collar on the opposite side of the rub to fix mine until I went BB springs.. The traxxas spacers are very cheap and with the lower ae BB cups it's real easy.. Good idea with the shrink wrap,much better than my old fix...
