Would this Kit work for the mod?
https://www.amainhobbies.com/avid-rc-mod-triad-slipper-clutch-81t-84t-avd1020-mod/p-quqwtaeqgc2xactz
Upgrading top shaft of stealth
- BohemianBabyDev
- Has thanked: 28 times
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Upgrading top shaft of stealth
I am running that on my sons car. Make sure you have the correct top shaft.BohemianBabyDev wrote: ↑Tue Nov 09, 2021 6:26 pm Would this Kit work for the mod?
Note that this one https://www.avidrc.com/product/5/accessories/3506/Associated-Aluminum-Topshaft-B4-Stealth-AV10062-accessories.html
Does not have a built in spacer, similar to the kit original top shaft.
I had to put a bushing between the stealth transmission body and back of the triad slipper plate for it to tighten down and work properly.
- BohemianBabyDev
Thank you for that, at least I know what to buy to upgrade my RC10T stealth.JosephS wrote: ↑Tue Nov 09, 2021 8:55 pm I am running that on my sons car. Make sure you have the correct top shaft.
Note that this one does not have a built in spacer, similar to the kit original top shaft.
Do you have a picture of where you set the bushing as a spacer and how it should look?
What size bushing? or Brand?
I used the associated 3/16 brass bushing that the front tires use. I set the bushing between the back plate of the Triad. It buried in the felt seal.BohemianBabyDev wrote: ↑Fri Nov 12, 2021 2:29 amThank you for that, at least I know what to buy to upgrade my RC10T stealth.JosephS wrote: ↑Tue Nov 09, 2021 8:55 pm I am running that on my sons car. Make sure you have the correct top shaft.
Is there a reason that you need to upgrade the slipper? I have one truck with the stock slipped and one with the stock slipper and I don't think I could honestly tell the difference once they were set.
- 24 Replies
- 4924 Views
Last post by JosephS
- 2033 Views
Last post by CrazyRC
- 1032 Views
Last post by ljh501
- 2110 Views
Last post by Chillout47
- 1538 Views
Last post by 68sportcoup
- 1085 Views
- 222 Views
- 660 Views
Last post by Frankentruck
Users browsing this forum: Bing [Bot] and 4 guests
