Run specs:
24 tooth Robinson pinion
54 tooth spur
32 pitch gears
4.2 inch Pro Line Street fighter beadlock tires.
Stock stealth GT2 transmission with upgraded high torque slipper pads
Slipper tightend down and backed off 1/4 turn
Diff tightened down and backed off 1/4 turn
Chassis lowered drastically
3 reedy saddle packs (3s) 20c 4800mAh
Mamba Monster X ESC
2650kv castle motor
45.6 MPH (dual GPS verified)
Castle link info:
31,605 RPM
100% throttle achieved
101.8 degrees max ESC temp
64 amp, 733 watt max draw (limited by 4mm bullet plugs)
1.66 voltage ripple (yikes)
12.9 max voltage (wat? It's 12.6 I confirmed each pack at 4.20)
Call with castle:
I called with a concern that the RC calculater said I should see 71 MPH. I was instructed to open the link program and read the above details. He told me that all is well with my setup. He said that scriptasylum's calculater is just a tool and is not always accurate. He also told me the ESC will never see the max voltage, especially from 3- 20C 4mm bullet saddle packs. I was told that under 35c can void my warranty as the resistance is too high. That aside, my RPM is exactly where the calculater puts me at 11.5v max, and that is what the castle link shows I achieved in both RPM and average voltage. The max voltage spike. This 12.9 is real, but it is a split second spike, or ripple. Not good. Caused by the 20C packs.
Prognosis from castle:
Step to a 4s 50-100c quality single battery. I am way under powered and taxing the system by way of resistance. Not saddles and a minimum of 10ga wire. The ESC is functioning as it should now but I need to stop attempting speed runs with 20c crap batteries and step up to a better battery. Also the 101 degrees is laughable. He told me 4s and then recheck. If I can handle it still, and it's under 135 degrees (no fan running), then I was told by castle to step up to a larger pinion.
The good news is with a locked diff and slipper it acts as it should. Like an untamed wild beast.
100c 4s shorty lipo battery research is about to commence. More to come.
