870C and Hotdog build
- 59burst
Re: 870C and Hotdog build
trying 870C rear shocks and tower with Hotdog4. 870C got CC rear tower and I probably go with this setup
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
First time i try this on my mobile...
but you get the idea. Beside the battery posts i used 4 servo posts and scrap graphite material. The servo and servo saver were swapped over from right to left
The battery top strap is missing; i havent run the car for awhile
- 59burst
not easy to see from this small picture. but I can't put the battery like that way on my narrow Hotdog4 ( = YR4) chassis for off road.Mr. ED wrote:First time i try this on my mobile...The battery top strap is missing; i havent run the car for awhilebut you get the idea. Beside the battery posts i used 4 servo posts and scrap graphite material. The servo and servo saver were swapped over from right to left
- Mr. ED
I found a better app. This should be bigger...
The chassis of the hotdog is large enough to do this, but I don't know whether the body will still fit.
- 59burst
- Mr. ED
59burst wrote:... but it looks ugly![]()
It looks better with the battery in place and wiring cleaned up
- 59burst
- 59burst
- 59burst
1/8" thick shock towers and G10 top deck. thanks to GoMachV.
the clearance between the battery and the belt is now 2mm with the epoxy holders
- 1109 Views
Last post by tudor39
- 1258 Views
Last post by Alex B
- 889 Views
Last post by Mr. ED
- 69 Replies
- 6783 Views
Last post by mikea96
- 3962 Views
Last post by caesar
- 2481 Views
Last post by scoobyrs25
- 1927 Views
Last post by OldSkoolRC
- 40 Replies
- 4091 Views
Last post by tdevilman77
