That's a narrow body, probably isn't going to work unless you modify or swap the rear shock tower. The shock tower swap is not that big of a deal, but handling does suffer a little bit.hugger19 wrote:lol i thought finding a body was going to be easy. i think iam going with this one. http://www.ebay.com/itm/9516-RC10GT-RC10-GT-TRUCK-BODY-VINTAGE-GAS-NITRO-/151567770978 looks close to that rc10gt chevy truck body u sent me by stormer hobbies. thanks.
my blue chassis rc10gt
- Been thanked: 5 times
Re: need some info/help
I don't have the part number right now, but this is the one you need, the original one from the first gen GT. I can get the part number when i get home if you want. Or you can just trim down the one you have, it already has the holes for the shock mounts drilled in it anyway.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Can you measure the wheelbase quickly hugger?
- RC10th
You probably wont know which body will fit till you get the truck. I just measured an early tub truck and a later longer FT flat chassis truck. I think the early first release flat chassis RTR trucks are on the shorter dimensions (I can't confirm 100% as I don't have one) while the RTR Plus was based on the longer FT style chassis.
I think your truck may be a longer RTR plus due to the plastic nose tube mounts, the early flat chassis RTR's had smaller metal nose tube mounts. These mounts aren't interchangable if I remember correctly.
Early short trucks are around an 11" wheelbase.
Later long trucks are around an 11 1/4" wheelbase.
If you have a short chassis any of these bodies will fit if you replace the rear shock tower with a narrow #7655 tower, or cut the ears off the the wide tower. The narrow tower was never offered in black fiberglass however if you want to upgrade it Fiber-lyte makes a narrow carbon tower. Also note if you cut the ears off a wide tower the shock mounting locations will be a bit lower.
http://www.ebay.com/itm/ASSOCIATED-RC10GT-RC10-GT-TRUCK-BODY-6131-VINTAGE-GAS-NITRO-/151673548686?pt=LH_DefaultDomain_0&hash=item235072af8e
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWZ10&P=7
If you have a short truck with narrow or wide rear tower this body will fit without any modifications.
http://www.ebay.com/itm/ASSOCIATED-6134-RC10GT-RC10-GT-TRUCK-BODY-VINTAGE-GAS-NITRO-/111591434767?pt=LH_DefaultDomain_0&hash=item19fb5e2a0f
If you have the longer chassis you'll need one of these. Or as justin said if you can find a Proline Crowd Pleazer or Silverado.
http://www.ebay.com/itm/3078-RC10GT-RC10-GT-F150-TRUCK-BODY-for-the-blue-gt-chassis-team-associated-/111497382528?pt=LH_DefaultDomain_0&hash=item19f5c30a80
- Has thanked: 25 times
- Been thanked: 143 times
http://www.ebay.com/itm/111497382528?_trksid=p2060353.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT went with this body going to have andy paint it up
- RC10th
That will fit a longer truck fine, good choice. It's the same body that came with the FT versions, a Proline F-150 copy.
Good choice, that's my favorite GT body.hugger19 wrote:http://www.ebay.com/itm/111497382528?_trksid=p2060353.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT went with this body going to have andy paint it up
You are correct about the rtr being tub chassis length, and the plus being factory team length. The length difference on all of the bodies is negligible, though. The factory team F150 was actually a "short" body originally designed for the tub chassis.RC10th wrote:You probably wont know which body will fit till you get the truck. I just measured an early tub truck and a later longer FT flat chassis truck. I think the early first release flat chassis RTR trucks are on the shorter dimensions (I can't confirm 100% as I don't have one) while the RTR Plus was based on the longer FT style chassis.
Re: my blue chassis rc10gt
got around to post some pics. sending the body off to andys for a vintage paint job. overall this trucks pretty clean. has rpm rod ends, frt/rear arms and a andys frt bumper.
- 3585 Views
Last post by justinspeed79
- 4701 Views
Last post by mAdMan
- 1075 Views
Last post by Dessertrat
- 1101 Views
Last post by ChisaiKuso
- 27 Replies
- 3513 Views
Last post by THEYTOOKMYTHUMB
- 28 Replies
- 3226 Views
Last post by allaircooled
- 1003 Views
Last post by badhoopty
- 1473 Views
Last post by mrlexan
